20 Most Recent Mag Innovision InnoVision XJ 796 Monitor Questions & Answers
3answers
My monitor was fine for
check the cable connected to the monitor run another monitor on your pc and if it does the same , try installing a serarate graphics board and if you are already doing that, replace that graphic board
5/23/2017 7:57:08 AM • Mag Innovision... • Answered on May 23, 2017
Where can I purchase a monitor base for the m26lm 26 inch monitor
wal-mart or best buy. In the area of wall mounts. good luck.
10/25/2014 6:01:03 AM • Mag Innovision... • Answered on Oct 25, 2014
No sound on computer- MAG Innovision Model 468
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc hope this helps
4/20/2014 6:42:04 PM • Mag Innovision... • Answered on Apr 20, 2014
0answers
0answers
0answers
0answers
MAG 2209A
Be the first to answer 12/6/2013 8:00:33 AM • Mag Innovision... • Posted on Dec 06, 2013Be the first to answer
Warranty for led monitor
whatever the manufacture says it is
11/24/2013 9:06:31 AM • Mag Innovision... • Answered on Nov 24, 2013
0answers
0answers
After resting problem getting screen back
It is possible that you have connected two cables from Monitor to CPU,We need to check if there's a cable that has blue connector (VGA) and another that is HDMI(may be black in color) or DVI (white connector).In case there are two cables that go from the monitor to the computer tower I would suggest you to removing one of the cables will resolve the issue.Feel free to revert for any further assistance
3/11/2013 6:47:42 AM • Mag Innovision... • Answered on Mar 11, 2013
0answers
Blurry flat screen monitor
yes you can use those button to adjust the brightness. just press one of the button then it will appear the set up and adjustment.
10/8/2012 11:07:37 AM • Mag Innovision... • Answered on Oct 08, 2012
Mag innovision monitor keeps turning off
It's not communicating with PC video card. It should pick up the input port, but make sure on monitor is set to correct input like VGA. You can try re-seating video card. Also test with VGA if you are using HD like HDMI.
8/31/2012 4:13:06 PM • Mag Innovision... • Answered on Aug 31, 2012
Mag Innovision InnoVision XJ 796 Monitor Logo
0 questions posted
Top Mag Innovision Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XJ Mag Innovision
  • XJ Mag Innovision
Most Popular Question
hey mag 900p monitor see
  • Computers & Internet
