20 Most Recent Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Questions & Answers
How do I replace power switch on fantom gforce 1tb
I have the same problem. These guys are clueless. I removed the warrenty sticker, undid the screws, and slid the hard drive bracket out easily with a little push. Unplug the wire connecting the power switch to the board. Push the switch out from the inside, applying presure to the top and bottom. You've removed the faulty switch. Replacing it is my new problem.
4/20/2013 11:42:38 PM • Fantom G-Force... • Answered on Apr 20, 2013
Forgot to 'un-dock' 1Tb Green Drive before disconnecting from computer, now computer doesn't see it. Turning Fantom on, hear 3 weak 'chirps' but no further motor noise. Have I to
check it on some other system also if result is the same then change the usb cable then check
1/28/2013 7:43:59 AM • Fantom G-Force... • Answered on Jan 28, 2013
Will not run when plugged in or to the computer
If this external hard drive uses a power adapter and when it is plugged into the mains socket and you do not get a blue light or hear the hard drive spinn then most likely the power adapter is faulty and cannot supply power to the hard drive.
4/21/2012 10:50:44 AM • Fantom G-Force... • Answered on Apr 21, 2012
My Fantom Greendrive is not being recognized by my computer whats the problem?
make sure the lead/s that attach to your hard drive are securely seated if your computer came with a motherboard disc the drivers could be on it click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver hope this helps
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
3/11/2012 9:09:55 PM • Fantom G-Force... • Answered on Mar 11, 2012
The USB is detected but
Hi,Normally the driver is preinstalled with the operating system.If there the driver is not getting installed properly, you will have to remove the drivers and let the OS reinstall it once more.Can you tell me which OS you are using?
12/14/2011 3:43:38 PM • Fantom G-Force... • Answered on Dec 14, 2011
My device is unrecognized by windows vista it keeps saying I need to update the driver but this I know is built into the unit is there a fix for this?
Hi,Try uninstalling the Generic USB Hub and USB root HUB drivers listed in your computer.Restart the computer and then try connecting the HDD once more.
12/7/2011 4:06:33 PM • Fantom G-Force... • Answered on Dec 07, 2011
Went to use it today and it fell on the floor and
Freezing a dropped drive wont help it.
The clicking you hear is a mechanical issue.
The drive is seeking it's "home" position" and cannot find it.
The data would need to be invaluable to send to a data recovery service and most start there evaluation at $300-$500 and charge by the megabyte for restored data
You can replace a 1Tb drive today for less then $100
8/16/2011 12:51:30 AM • Fantom G-Force... • Answered on Aug 16, 2011
The Hard Drive is on.
Hello vunit2007,
I've read your "post," and I think that the best solution to the 'problem is to:
Get an "Update on the Drivers and Software. "Most situations cannot be solve by 'pressing a couple of buttons'; sometimes We have to go into the "Control Panel," or go to a "Website" to get updates for the computer, "Drivers are needed for Hardware, eg, (Hard Drives, Printers, CD / DVD Players, Audio Sound, Speakers, Microphones, Mouse, Keyboards, and Webcams), to work correctly; also, some Software products." "Upgrading the computer in any way, or added a 'new' software product?" Causes the System Configurations, to change! Many cases involving "Upgrades from an 'older' {Operating System, eg. XP or Vista}, to Windows 7, can cause a change in "Hardware Devices," not functioning properly; or not to work at all!" "These easy instructions will help you solve these issues, and hopefully, we'll be able to fix the problem the first time." "This is what you need to do first!" 1. Click on the Website [below].2. Download the Fantom G-Force MegaDisk {NAS Source Code}, at the [botton of the page].3.Turn-off the computer.4. Disconnect the Hard drive.5. Restart the computer.6. Install the Drivers.7. Restart the computer again.8. Connect the Hard Drive.9. Turn on the Hard Drive.10. Check the in the -> Control Panel -> Device Manager -> Hard Drive / Mega Disk!11. Check in the Disk Management. "Let me know if you need more help, if it didn't fix the problem? Post a "Comment" to get more help. "I would appreciate it if you let me know! Best Regards, paul7of9 Click here for Download: http://www.micronet.com/support/software.htmScroll to the bottom of the page until you see the download for the "Fantom G-Force MegaDisk
6/15/2011 2:57:00 AM • Fantom G-Force... • Answered on Jun 15, 2011
None of my computers recognize my hard drive, and
Change the usb cable for one that you know works.
5/2/2011 10:13:23 PM • Fantom G-Force... • Answered on May 02, 2011
I think I did a
Connect it to a PC, and use "Disk Management" on the PC to delete all the partitions:
Click Start
Right-click My Computer
Click Manage
Expand "Storage"
Click "Disk Management (local)"
Click to select the partition.
Right-click and choose Delete.
11/18/2010 6:42:50 PM • Fantom G-Force... • Answered on Nov 18, 2010
My fantom drive greendrive green
Its an issue with connectivity.
Check the USB connection.
9/29/2010 6:06:47 AM • Fantom G-Force... • Answered on Sep 29, 2010
My computers can not see the drive
It maybe the usb connection that is faulty. As a last resort you can take the drive out of that enclosure and fit it into a new caddy, or fit it straight inside a pc
7/12/2010 9:37:43 PM • Fantom G-Force... • Answered on Jul 12, 2010
How do I open the case to my fantom drive?
remove "Warranty void if removed" sticker on bottom of case... unscrew screws...
5/29/2010 4:53:48 PM • Fantom G-Force... • Answered on May 29, 2010
Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
5/27/2010 7:09:19 PM • Fantom G-Force... • Answered on May 27, 2010
Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Logo
37 questions posted
Top Fantom Computers & Internet Experts
NOEL
NOEL
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fantom Computers & Internet
Most Popular Question
computers not see drive
  • Computers & Internet
