20 Most Recent Mitsubishi WD-73927 73" HDTV Questions & Answers
What could be a problem if the tv is glitching
describe the problem more?
6/14/2012 7:37:18 PM • Mitsubishi... • Answered on Jun 14, 2012
My tv made a loud
That pop sound was your lamp blowing up. The crackling you here now is the ballast trying to light the lamp. Replace your lamp.
4/14/2011 8:15:55 PM • Mitsubishi... • Answered on Apr 14, 2011
I need a screen for wd73733 Mitsubishi dlp were
You can try www.partstore.com, and you can call your local TV repair shops, sometimes, they have exter screens lying around.
2/14/2011 8:42:05 PM • Mitsubishi... • Answered on Feb 14, 2011
TV was on but picture wasn't as clear. I pressed
Try the soft reset, with set on and original remote hit 1,2,3 enter, some versions require menu first.
let me know if it helps.
The set also has a hard reset but only as a last resort.
SD TECH
2/11/2011 2:53:29 AM • Mitsubishi... • Answered on Feb 11, 2011
I have a new diamond
U buy this tv as a brand new tv not as an open box product?Yes.U have the wright to return this tv and get a replacement tv from that store.If tv was bought as a open box product,call mitsubishi for a warrenty repair.
10/25/2010 8:43:03 PM • Mitsubishi... • Answered on Oct 25, 2010
DLP TV - After warm up - colors smear
Did you ever figure the problem out? My TV is doing the same thing.
9/23/2010 6:31:45 PM • Mitsubishi... • Answered on Sep 23, 2010
Shadow across top of screen 1-2 inches thick
I have the same problem on my Mitsubishi set. Anyone have a solution for this problem yet?
9/2/2010 5:55:50 PM • Mitsubishi... • Answered on Sep 02, 2010
72 in shuts off 3x every 10 min.new bulb 7 th one
You need to check on the power supply board for Bad Capacitors they will be vented,swollen, or puffed up on Top. 680uf 10v,330uf 10v 3300uf 10v 2200uf 10v,
9/1/2010 4:33:14 PM • Mitsubishi... • Answered on Sep 01, 2010
Where can i get 3d glasses for a c9 series tv?
Tries websites like Amazon.com or Ebay.com should have it.
4/21/2010 5:09:12 AM • Mitsubishi... • Answered on Apr 21, 2010
2answers
My tv blinks 6x red and 1x yellow. whats that mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
1/9/2023 7:23:43 AM • Mitsubishi WD... • Answered on Jan 09, 2023
0answers
How to replace the main board on a mitsubishi WD-60C8
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
1/18/2018 11:51:33 PM • Mitsubishi WD... • Answered on Jan 18, 2018
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
1/2/2018 10:55:36 AM • Mitsubishi WD... • Answered on Jan 02, 2018
Mitsubishi WD-73927 73" HDTV Logo
16 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
need screen wd73733 mitsubishi dlp
  • Televison & Video
