20 Most Recent Shure SM58 Professional Microphone Questions & Answers
2answers
I have Shure SM58 microphone, I need receiver w/a frequency of 183.600.
You would need to look for a used one on eBay or Craigslist.
4/15/2022 11:30:19 AM • Shure SM58... • Answered on Apr 15, 2022
My sm58 has a low
This could be any of several things. IF the audio output of the mic is at a normal level then the first thing to check is the mic cable. I have several things to discuss so read all of this and then test.
First, I found six BRAND NEW XLR cables were wired wrong... the vendor had 13000 of them in stock and was going to have to check them all. The cables appear to work, but had the shield and one signal wire in the wrong place so the line was NOT a twisted pair balanced as required, but instead a plain coax. I had to repair these at a venue when I discovered the problem. Please google the correct XLR configuration. The pin numbering is NOT what one would expect. You cables (open the ends and look) should have the shield tied to pin 1 which is one of the side pins. Mine they had the shield on the middle pin or apex of the triangle.
Second, there are COUNTERFEIT Shure SM58's being sold. Read about that at google... If you unscrew the screen and find a label on the side of the element, the mic is a fake... Now there are two qualities of fakes... some perform ABOUT as good as the genuine, and others don't even have the balancing transformer.
If the hum is only there while handling the mic, the ground to the shell is not connected... this is mainly a mechanical connection. You can extract the XLR male plug from the bottom of the mic by removing the side screw and gently pull out by grabbing one of the pins. Also you can verify the wire colors as the fakes use the wrong color wires.
Noise problems are my specialty so if you need further help send a comment to me.
5/22/2019 4:16:47 PM • Shure SM58... • Answered on May 22, 2019
2answers
Microphone won't turn on
When you say "turn on" the SM58 does not normally have an on/off switch on the mike. Does yours? If so, bypass the switch. Did you try different cables or another mike on this one's cable? The SM58 is a very rugged mike but can be damaged. I'd make sure all cables, connectors, and such are good before suspecting the mike itself.
9/3/2015 11:29:04 PM • Shure SM58... • Answered on Sep 03, 2015
2answers
I get ALOT of feed back, why? I can't use it like that. I've talk with the a Tech and he said I needed to stand further away from the amp, which I am.
This sounds like your gain is too high. Adjust it down. Every mic has different gain settings so you can't just blanket this with the other one works fine. Is this wired or wireless?
4/28/2015 5:39:06 PM • Shure SM58... • Answered on Apr 28, 2015
How do you take a sm85 microphone apart
Unscrew the top portion with your hands to expose the capsule. The connector at the bottom is unscrewed with either a small phillips or slot screwdriver.
12/29/2014 3:04:34 PM • Shure SM58... • Answered on Dec 29, 2014
Sm58 no low frequency response
Contact Shure for repiars.
7/27/2014 3:16:26 AM • Shure SM58... • Answered on Jul 27, 2014
Where can I purchase a replacement Head for the LX2 microphone, SM58 or PG58?
Contact any Shure dealer.
7/27/2014 3:11:11 AM • Shure SM58... • Answered on Jul 27, 2014
Error code e
What model?
7/27/2014 3:08:43 AM • Shure SM58... • Answered on Jul 27, 2014
How so syn shure sm58 mic with shure receiver?
Which model?
7/27/2014 3:07:47 AM • Shure SM58... • Answered on Jul 27, 2014
How to break incopatable code on shure microphone
The transmitter and receiver MUST be in the same frequency band.
7/27/2014 3:03:00 AM • Shure SM58... • Answered on Jul 27, 2014
The centre part on my 58 needs replacing what site should i use
Contact Shure Parts for replacement parts.
7/27/2014 2:58:37 AM • Shure SM58... • Answered on Jul 27, 2014
Weak sound
Turn up the volume level on the mixer.
7/27/2014 2:56:21 AM • Shure SM58... • Answered on Jul 27, 2014
How can I sync a Shure T2 mic to a LX4 receiver
There is no sync. They simply need to have the same frequency listed on their sitickers.
7/27/2014 2:55:00 AM • Shure SM58... • Answered on Jul 27, 2014
Why microphone shure sm 58 have difference quality
Compared to what?
7/27/2014 2:28:15 AM • Shure SM58... • Answered on Jul 27, 2014
How do I sync my
It depends on the wireless model. Follow the instructions in the User Guide or look at the videos Shure has produced.
7/27/2014 2:27:55 AM • Shure SM58... • Answered on Jul 27, 2014
My wireless shure sm58 microphone
You got the mic into the Master List. Instructions are in the User Guide.
7/27/2014 2:22:31 AM • Shure SM58... • Answered on Jul 27, 2014
Shure sm58 wireless won't sync with pgx4
See the following: http://shure.custhelp.com/app/answers/detail/a_id/363
7/27/2014 2:14:28 AM • Shure SM58... • Answered on Jul 27, 2014
Cracked Shure SM58 handle/housing can I replace the handle/housing?
Contact Shure for repair and parts.
7/27/2014 2:08:39 AM • Shure SM58... • Answered on Jul 27, 2014
Repairing shure wireless mic capsule
Contact Shure for Repairs.
7/27/2014 2:07:17 AM • Shure SM58... • Answered on Jul 27, 2014
Shure SM58 Professional Microphone Logo
141 questions posted
Top Shure Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Shure Audio Players & Recorders
Most Popular Question
purchase replacement head lx2
  • Audio Players & Recorders
