20 Most Recent
Optoma RD50 Television Questions & Answers
I have an Optoma RD
Tries RCA component a cable like YRW video cable.Connect tv and the blu-ray that way throught RCA holes and cables should work too.
I replaced my RD50's lamp recently and everything
There should be a reset lamp function in the service section of the menu. If there isn't, there is a way to do it by pushing and holding a sequence of buttons on the tv or remote. It varys from model to model. Check your manaul to see what the correct proceedure would be for your model.
Unit will not power up, it goes from red to orange
First, try to power cycle the projection TV by unplugging the power cord from the wall socket and leave it unplug for about 30 minutes and then turn it back on.
Make sure that there's enough space between the wall and the back of the projection TV.
Since the lamp is newly replaced, it could be the lamp cover. Check the lamp cover again and make sure that it is properly screwed and not moving. This could cause the projection TV not to work.
Aside from that, check also the fuses and the power supply. You might need an assistance from a repair tech that has the right equipment to test it.
These are the possible cause of the problem.
Optoma a51 presenta logo y apaga y luego hace lo mismo
Si su Optoma A51 solo muestra el logotipo de inicio y luego se apaga, y luego lo hace de nuevo, es posible que tenga un problema con el proyector o la l?mpara. Aqu? hay algunas cosas que puede intentar para solucionar el problema:
Aseg?rese de que la l?mpara est? correctamente instalada y de que no haya da?os en la carcasa o en la conexi?n.
Verifique que la entrada de alimentaci?n est? correctamente enchufada y que el cable de alimentaci?n no est? da?ado.
Compruebe si hay problemas de sobrecalentamiento en el proyector, aseg?rese de que la ventilaci?n est? libre de obstrucciones y de que no est? demasiado cerca de una fuente de calor.
Si todo lo dem?s falla, es posible que deba llevar su proyector a un t?cnico para que lo revise y repare si es necesario.
Espero que esto ayude a solucionar su problema.
Preciso de um controle remoto projetor Optoma EP 739 onde comprar
Question edited for clarity.
Question edited.
English only on Fixya please!
OPTOMA EP-739 - remote control - replacement - $17.4
https://www.remote-control-world.eu > optoma-ep-739-...
Replacement remote control OPTOMA EP-739 (EP739) - 100% replacement 1:1 of ... It is not an universal remote, but dedicated for projector models listed above.
Video Projector Remote Control for Optoma ep739
https://www.amazon.com > Video-Projector-Remote-Co...
Tekswamp remote features comfortable, easy to reach buttons in a compact, rectangular body, convenient for everyday use and transportation.
Compatible Devices: Video Projector
Batteries: 2 AAA batteries required
Brand: Tekswamp
Number of Batteries: 2 AAA batteries required
Rating: 1 · 1 review · US$19.99 · In stock
https://www.ebay.com > itm > brand=Optoma
Features: Infrard ; Year Manufactured: 2020 ; Wireless Range: 5-10 m ; Compatible Brand: For Acer, For BenQ, For Canon, For Sanyo, For Panasonic, For PROMETHEAN, ...
Type: DLP Projector Remote control
Compatible Model: Universal
Compatible Brand: For Acer, For BenQ, For Ca...
I've got anissue with an oldie-but-goodie Optoma HD65 (NOT the UHD-65). About 45 minutes after powering it down, I powered it back up after installing a powered & powered up Monoprice HDMI splitter and new HDMI cable between my AVR (Denon AVR-2310CI, powered down) and the powered-down Optoma. Nothing happened.
ALL THREE LEDs (Power, Lamp, Temp) are flashing red, and more quickly than the Service and Owners' manuals.indicate for a lamp issue (1-sec. interval). The lamp was replaced early last fall, about ~800 hrs. ago...that was an easy diagnosis, as I heard the prior lamp explode; this one didn't, and looks O.K., out of its housing and cartridge. The current lamp was claimed to be OEM by an Ebay seller (he sold both OEM and "compatable" lamps). That's all I know...Any ideas, please?
Remote is not advancing powerpoint
Hi, Projector sensor never get damage.It all way the remote,because remotes
devices are heavy depend on it CPU chip.All way the CPU chip on the
remote is dying and shorted,it always lost some functions or die
completely.Try website like http://www.remotes.com/ to buy an original or very close
to it remote.
Or if the device is still under warranty,you can contact them from the below link.
http://www.optoma.eu/warranty.aspx
Good luck..
