20 Most Recent Nikon D70 Digital Camera with 18-70mm Lens Questions & Answers
0x80070057 parameter is incorrect
Try NOT connecting your camera to your computer. The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/25/2014 6:06:41 AM • Nikon D70... • Answered on Nov 25, 2014
Camera works,all lite up and functions work
Purple haze usually indicates an image sensor failure. However, the fact that it only does it with one of your lenses is strange.
5/5/2013 4:50:03 AM • Nikon D70... • Answered on May 05, 2013
0answers
D70 err r07
Be the first to answer 1/27/2012 4:04:29 AM • Nikon D70... • Posted on Jan 27, 2012Be the first to answer
How do I get a wireless remote to work? I have
Assuming you're referring to the ML-L3 remote, you need to set the camera's shooting model to one of the two remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To change the camera's shooting mode, press the shooting mode button (overlapping rectangles) and turn the main command dial (on the back of the camera). The quick-response remote mode is indicated by a picture of the remote. The delayed remote mode is indicated by the remote and a one-handed clock.
The remote needs to be pointed in the general direction of the receiver on the front of the camera, above the "D70" nameplate.
8/1/2011 6:14:05 PM • Nikon D70... • Answered on Aug 01, 2011
Everytime i connect my nikon d70 to my laptop,
You can try downloading the camera drivers directly from Nikon's website then see if the computer recognizes the camera, if not you will need to use a different computer to avoid a card reader.
7/30/2011 2:05:00 AM • Nikon D70... • Answered on Jul 30, 2011
Cant take any pictures ... code reads off r33 what does that mean
check to see if auto lever on rear is on dot. I accidentally moved mine and camera would not focus or fire when I was in automatic mode. I went to manual and everything was okay. Switched back to full auto and had same old problem.
7/25/2011 6:43:40 PM • Nikon D70... • Answered on Jul 25, 2011
I was given a nikon d70 but the manual is missing.
try down load this http://www.nikonusa.com/pdf/manuals/dslr/D70_en.pdf
3/4/2011 2:10:53 PM • Nikon D70... • Answered on Mar 04, 2011
D70 card pcb has broken pin can i get a pin
If you want the entire memory card slot assembly, you can order one at
http://uscamera.com/1c998-634.htm
1/16/2011 10:55:50 PM • Nikon D70... • Answered on Jan 16, 2011
Hi My Nikon D70 only now
This is a 2004 camera model. Even if it was a known problem, Nikon would have fixed them out of warranty for free for only a limited period of time. You've gone way past that time. If you still want it fixed, get an estimate from Nikon and search the internet for other service centers that repair Nikons and get their estimates too. Then, make your decision.
10/1/2010 6:55:20 PM • Nikon D70... • Answered on Oct 01, 2010
My camera keeps saying this card cannot be used i
Did you format them in the camera (recommended) or in the computer (not recommended)?
3/22/2010 9:09:49 PM • Nikon D70... • Answered on Mar 22, 2010
Flashing chr and tried everything
questions as bare as this are less likely to be answered because they contain no information of value to the reader to assist you in solving the problem.
?chr? charger? chair? character? ( abbreviation)
If the unit is on charge flashes but does not charge, suspect a faulty charge system circuit or a dead battery unit that needs to be replaced.
Please rate my attempt to solkve this question+_+++Thankis for using FIXYA
3/21/2010 7:08:18 AM • Nikon D70... • Answered on Mar 21, 2010
D70 photos not sharp - no matter which lens I use.
D70 produces lovely crisp images as long as the lens is pretty good.  This sounds like a camera body that needs a service.,,
3/11/2010 6:56:24 AM • Nikon D70... • Answered on Mar 11, 2010
0answers
When I press shutter release button, it fails to shoot.
i can solve this problem
contact : foto mohamed, Digital Camera Repairs
st.pelagia bldg,Vasco-Da-Gama, Goa.
Mb:9890274954 / Ph: 832-2517047 of international add dubble zero 00832
6/19/2009 5:34:58 PM • Nikon D70... • Answered on Jun 19, 2009
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
5/18/2009 6:16:24 PM • Nikon D70... • Answered on May 18, 2009
Images are on the memory card but I can't even download them
Hello Irredessence,
I know how it feels when you loose your expensive memories.. :(
However there is still a small hope; there are softwares available that can recover deleted/corrupted files back... I googled for "memory card data recovery software" and there were bunch of them.. choose the one that suits you.. you should find few good sharewares too.
All the best and let me know if you were able to recover any.
Thanks and Regards,
Srinivas
4/10/2009 9:24:23 AM • Nikon D70... • Answered on Apr 10, 2009
Nikon D70 Digital Camera with 18-70mm Lens Logo
36 questions posted
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
d70 card pcb broken pin get pin
  • Cameras
