20 Most Recent Hifonics Brutus BX 1505D Car Audio Amplifier Questions & Answers
0answers
Hifonics 1500D started to hum through subs after
Check power supply diods. power supply capacitors and power supply and output transistors.
Remember, distortion is the biggest killer of subs and amps. Everything made by anybody has its limit.
4/17/2010 7:59:23 AM • Hifonics Brutus... • Answered on Apr 17, 2010
The remote starter cable came off
loosen off the remote wire screw, you may need to strip some of the wire insulation back, place bare copper wire under screw and tighten screw back over wire
3/29/2010 1:37:38 AM • Hifonics Brutus... • Answered on Mar 29, 2010
Car audio amplifier making noise internally but no sound output
Without actually seeing the components your are describing I am only speculating however they could be a type of Film capacitor. Judging by where the location is I wouldn't think they would be power resistors because they are located next to the electrolytic caps for the power supply. They could possibly be coupling capacitors but due to the location I doubt it. If you can remove the fets from the board I can tell you how to test them, just look at the part number so i know what it is. There are also many tutorials on testing FETs on the net you just need a multi meter.
1/5/2010 5:20:20 PM • Hifonics Brutus... • Answered on Jan 05, 2010
2answers
Hifonics Taurus circuit diagra???
You need to measure the voltages at the output transistors. The previous "driver" stage may have a problem. These outputs use .6V as the bias differential. Check for DC voltage on the inputs to the transistors. These are standard designs. I'd check for DC anywhere along the signal path.
Dan
6/5/2009 11:05:09 PM • Hifonics Brutus... • Answered on Jun 05, 2009
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
2/24/2009 9:28:02 PM • Hifonics Brutus... • Answered on Feb 24, 2009
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
12/28/2007 5:33:45 AM • Hifonics Brutus... • Answered on Dec 28, 2007
Problem!
you have a foulty amp i wtake it bk and change it
12/27/2007 7:24:05 PM • Hifonics Brutus... • Answered on Dec 27, 2007
Amp does not work
make sure your power and ground wires are 4 gauge thats a big power puller also make sure your wires to woofers are correct!and you want a short ground wire and a good spot for it no paint!!
if there out of phase that will shut it off BUT you might be needing a battery cap. MORE POWER!!!!they dont cost much
and save your battery and alt.hifonics is a good choice my favorite are the series 7 they dont make them like that anymore!
hope this helps one more thing your alt.how many amps is it?
my honda is only 60 amps your brutus pulls that all day !
(BATT.CAP.or HAVE ALT.WRAPED for more power.
12/1/2007 3:33:59 PM • Hifonics Brutus... • Answered on Dec 01, 2007
Problemm
reset your sistem
12/1/2007 2:21:56 AM • Hifonics Brutus... • Answered on Dec 01, 2007
How to reset my system?
disconect all power cables then short between terminals G&P G&R .a little spark but ok.try after 10min.
8/22/2007 6:34:35 AM • Hifonics Brutus... • Answered on Aug 22, 2007
My stereo when I turn it up my capacitor starts beeping zero
Capacitors are static semiconductors, they don't beep and they don't display zero. You're overworking the system or you have bad connections. Contact the maker direct under warranty. https://www.google.com/search?q=Brutus+Hifonics ..
12/24/2022 5:06:04 AM • Hifonics Car... • Answered on Dec 24, 2022
Hifonics Titan TXi6006. I need to see a manual for it please.
Question edited for clarity. The manual for the TXi 4400 / TXi 6400 / TXi 8400 is probably close enough and is in the link. https://www.manualslib.com/manual/750566/Hifonics-Txi-4000.html?page=13#manual https://www.google.com/search?q=hifonics+txi6006+manual ..
8/18/2022 4:16:11 PM • Hifonics Car... • Answered on Aug 18, 2022
2answers
I have a hifonics hfi1000.1d im trying to hook up 2 kickercomp cvr12 iwant to bridge them and run them in series
My bad but I'm new to this website I don't see any answers here is that because there are none ? Or do I need to click on something to view the answers ??
8/9/2021 7:38:16 AM • Hifonics Car... • Answered on Aug 09, 2021
2answers
I have a Hifonics Brutus Bre 1600.1 D class amp, it powers up green light on so is the blue light on top but nothing comes out from speakers. What can the problem be and will it be an easy fix?
Your amp could still have a short not allowing it to provide audio to your speakers. Confirm that your speakers are not blown. Use VOM meter to confirm the ohm rating.
2/4/2019 4:19:24 AM • Hifonics Car... • Answered on Feb 04, 2019
My Hifonics zeus zrx1500 1D has protector light on and wont turn on after i inserted the remote
This means that the remote wire is 0V instead of 12V. Try to connect it over from the 12V to check if it powers on.
1/15/2019 3:11:55 PM • Hifonics Car... • Answered on Jan 15, 2019
Hifonics brutus 25th aniversary 1600 watt amp it turns on then slowly fades away what should I do
MKe sure you have 12 vole coming from m your remote will re after your system starts up.
12/3/2017 4:47:10 PM • Hifonics Car... • Answered on Dec 03, 2017
Hifonics Brutus BX 1505D Car Audio Amplifier Logo
Popular Tags
12 questions posted
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hifonics Car Audio & Video
Most Popular Question
hifonics 1500d started hum subs after
  • Car Audio & Video
