20 Most Recent Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive Questions & Answers
If there is a bios chip on the board, heat it to remove it and change it with the bios chip on the new board.
Western Digital... | Answered on Aug 16, 2017
Check WD's website for a Linux driver or Redhat's web page.
I just had the same problem today. I found this place.
http://www.lowcostrecovery.com/pricing.html
Western Digital... | Answered on Nov 06, 2012
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Western Digital... | Answered on Apr 27, 2011
Hard drive failure. Replace hard drive.
Western Digital... | Answered on Mar 18, 2011
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Western Digital... | Answered on Jan 05, 2011
once in system BIOS try f1 for general help or booting in optimised defaults or failsafe defaualts
Western Digital... | Answered on Aug 22, 2010
Hi, on the rear of the drive there are a series of pins with a small plug coveing two; you need to remove the pin and alter the placement for either, master or slave depending on what you are using the drive for; you will see a small diagram telling you where to place the plug. Hope this helps
Western Digital... | Answered on Jul 16, 2010
does he makes any sound (ticking)... while running?
dos it appear in the cmos setup under the first option?
Western Digital... | Answered on May 12, 2010
It would be very difficult to locate the spare parts for your hard-drive since it is manufactured 6 years back and is already out of warranty period. Even if one does manage to find the spare part, it is not sure that the drive will work. So,it would be better if you go for a data recovery procedure if you have valuable data on the disk.
Hope this helps. For more help and clarifications,please reply. Thanks.
Western Digital... | Answered on Aug 16, 2009
Does your drive make any sounds similar to these? If yes you have a mechanical problem and you should get a specialist to work on it if you need that data.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Western Digital... | Answered on May 09, 2009
see if there any updates for the xbox 360 in terms of flashing the bios or something along those lines - not sure if you can get into the configuration to alter any settings regarding or relating to detection of hard drives.
Are you still looking for the PCB?
Maybe I can help you to find it.
PM me on this forum http://forum.hddguru.com/hard-disk-drives-repair-and-data-recovery-f1/
Username: dav34
Western Digital... | Answered on Mar 06, 2009
All you have to do insert any operating system bootable disk and then boot in CD/DVD rom and partition HDD and format and then install the operaitng system.
Here a guide on installing windows xp operating sytem :
http://www.geekgirls.com/windowsxp_install.htm
hope this help
Western Digital... | Answered on Aug 16, 2008
Take it back to the store - this is a common problem with WD drives and WD are doing nothing to address this issue with their larger drives. Buy another make and you should be trouble free.
Western Digital... | Answered on Jul 20, 2008
Have you installed it as the main drive, ie the one with the ops system on, or have you installed it as a secondary drive? Either way, check you have the drive set up correctly as per instructions on pack. You are not alone with this problem either, it is common with WD. Come back to me with more info re your install.
Personally, I would set it up in an external enclosure and access via USB. Much more realable that way, and it is portable for you.
Hi, you dont say whether you have it installed in the pc, or is it in an external usb enclosure? Come back to me and I will try for you.
Hi, looks like your usb drive has died. Try it on another pc / laptop first. If it still does not work, you will need to purchase drive data reader while will allow you to access the data. Most pc stores carry them. Cost about 50 euros. Best of luck.
The hard drive will automatically install you do not need to install a driver. I'm guessing this is a hard drive in addition to the hard drive that vista is running on? If so you probably need to format the hard drive to gain access to it. Click the windows button, and in the search field type compmgmt.msc and hit enter. Click continue when the UAC pops up. Now inside the Computer Management Console find and click on Storage and then Disk Management. On the bottom portion look for your new hard drive. Most likely it will have a black colored stripe and say UNALLOCATED. This will explain how to do the rest Yes that article is for XP but the one in Vista is pretty much the same.
Western Digital... | Answered on May 16, 2008
Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive Logo
Popular Tags
28 questions posted
Top Western Digital Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
efs_perpends
efs_perpends
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Caviar Western Digital
  • Caviar Western Digital
Most Popular Question
wd caviar wd5000aajb spins
  • Computers & Internet
