20 Most Recent Evenflo Triumph 5 Questions & Answers
We have an evenflo triumph
Its possible the this LINK help you: evenflo.com/support
Or tyr to contact in evenflo.com/corporate
Hope helps.
9/6/2010 5:23:03 PM • Evenflo Triumph... • Answered on Sep 06, 2010
2answers
Remove Seat to Wash
I still had my manual and it said to unscrew the back; and you do have to take out the top of the straps to get the pad off. I just did this last weekend and then re-install everything. It worked great! The only problem I found was that when the pad is washed, the pad backing gets caught in the velcro and needs to be removed.
Hope that helps!
8/28/2009 2:01:37 PM • Evenflo Triumph... • Answered on Aug 28, 2009
How do I remove the cover of my evenflo triumph
hmm theres plastic tabs you have to remove
6/26/2009 9:56:15 PM • Evenflo Triumph... • Answered on Jun 26, 2009
Instruction for installing Evenflo Triumph
On the back of the car seat you should have a black hook with a safety latch on it connected to a adjustable strap. You will require an anchor point to connect this to in the back of your car, depending on your car (sedan, station wagon,4x4 ect) your anchor point will have a small removable cover over it about 1 inch square or so, if you have not got one already installed make sure you get the anchor as well. This will be a small metal latch with a spacer and bolt with a safety nut the nut goes under the bottom of the parcel shelf if it is a sedan if not you won't need the nut. The the hook will attach to the anchor and then you just loosen the adjustable strap out until it is fairly loose (about 3 or 4 inches of play between the car seat and the baby seat will be fine) now if the baby is small and needs the seat to lay down ie they can't hold there head up or are to small to face forward, have the head end of the baby seat to the front of the car and set the seat belt throught the hole thats horizontal to the car seat. If they can face forward same thing just stand seat upright and feed the seat belt through the horizontal holes. The hole for the seat belt should be about 2 to 3 inches high and about 4 or 5 inches long. Just becareful not to put the seat belt over the childs belts on the baby seat. Then just tighten the adjustable ******** the baby seat until firmly tightened against the car seat and you are done. The baby seat will still move a bit from side to side but if it moves more than 3 inches or so tighten the adjustable strap even more.
8/17/2008 9:27:17 PM • Evenflo Triumph... • Answered on Aug 17, 2008
I took it apart too much!! Help!
Manuals, pictures, brochures and a link to the maker. https://www.google.com/search?q=evenflo+triumph+car+seat+manual ..
6/15/2022 3:26:48 AM • Evenflo Baby... • Answered on Jun 15, 2022
Need printable manual foe Chase Evenflo car seat 30621633
Possibly similar model manual from manufacturer:https://www.evenflo.com/on/demandware.static/-/Sites-evenflo-Library/default/dw009a2787/Instruction%20Manuals/25701061%20-%20Chase%20Select%20EN%20Jan17.pdfReplacement parts from manufacturer:https://www.evenflo.com/parts-accessories/car-seat/30621633/30621633_parts.htmlhttps://www.evenflo.com/support/instruction-manuals.htmlhttps://www.google.com can be used to search for manuals, but unfortunately, the one I found appears to be a different model.https://www.manualslib.com/products/Evenflo-Chase-4041185.htmlPerhaps you could contact a retail store or internet site that sells that particular model and ask for a copy of the manual.
10/5/2019 5:20:07 PM • Evenflo Baby... • Answered on Oct 05, 2019
I'm looking for Assembly instructions for Evenflo Crib 11111 Lot 61901
Try this site that has a lot of manuals. https://www.manualslib.com/
4/5/2019 11:36:36 PM • Evenflo Baby... • Answered on Apr 05, 2019
How do I reattach the string to the back of the evenflo car seat?
Here is a picture of it. I am lucky that I have twins. I had another to go back and look at! Haha
12/16/2018 6:10:38 PM • Evenflo Baby... • Answered on Dec 16, 2018
I need instructions to assemble Evenflo Pack and Playyard.
Hello, Lenda - The Evenflo company web site does offer instruction manuals for many Evenflo products: https://www.evenflo.com/support/instruction-manuals.html There is a section on that web page, with the heading Playards & Portable Beds. Perhaps one of the model names listed there is the model name for your Pack and Playard. If not, then I suggest you contact Evenflo Customer Service and ask for assistance regarding the locked side rail. This is the link to the Evenflo Contact Us web page: https://www.evenflo.com/contactus If you reside in the USA or Canada, you will find a telephone number to call. Otherwise, you can fill out the form on that page to send as an email message. Best wishes.
9/23/2018 5:41:23 PM • Evenflo Baby... • Answered on Sep 23, 2018
2answers
How to convert symphony car seat to booster seat
Watch these 2 instructional videos on how to convert the Evenflo Symphony car seat here:http://www.evenflo.com/support.aspx?id=452http://www.evenflo.com/support.aspx?id=460
12/21/2017 6:42:13 AM • Evenflo Baby... • Answered on Dec 21, 2017
I have a Evenflo Triumph model 38221577. I took the back off and I can't put the string back on because I don't remember how it went on. I can send a picture. Help please!
In the market for a range hood and been doing some shopping around. Holy smokes?¯?¿?½.. I thought shopping for a new range was difficult, but shopping for a hood makes shopping for a range seem like a walk in the park. For the life of me I can't figure out, after the whole world seems to have moved to fluorescent or LED bulbs, that the hood industry is still using the extremely inefficient power sucking halogen bulbs. What?¯?¿?½s worst is that many of the range manufactures warn against changing out the halogen for a more efficient bulb with the fear causing damage. Is there a reason that I am missing? I have been looking at vent-a-hood and Broan among others.
11/12/2017 6:16:31 PM • Evenflo Baby... • Answered on Nov 12, 2017
How to operate evenflo baby monitor
Maybe contacting Evenflo and specifying your device you might get some information: https://plweb.evenflo.com/
8/31/2015 2:37:24 PM • Evenflo Baby... • Answered on Aug 31, 2015
Is this carseat expired
Hi Angie, Here is a link to Evenflo Support Good Luck! JP Evenflo Product Support
7/15/2015 1:49:40 AM • Evenflo Baby... • Answered on Jul 15, 2015
How doi put car seat belts back togethr
Hi We would recommend you contact Evenflo directly for assistance with your enquiry Evenflo Baby Car Seats Infant Carriers Baby Gates and Toddler Travel...
1/18/2015 2:55:25 PM • Evenflo Baby... • Answered on Jan 18, 2015
When is the expiration date on model number 3702805
I have one like this. Same model number and it expires on December 2015
10/27/2014 7:00:25 PM • Evenflo Baby... • Answered on Oct 27, 2014
Evenflo Triumph 5 Logo
7 questions posted
Top Evenflo Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
john h
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Evenflo Baby Gear
  • Evenflo Baby Gear
Most Popular Question
remove seat wash
  • Baby Gear
