20 Most Recent
Thermaltake (a2148) Mouse Questions & Answers
Hello
i get message 'please plugin
Go to this link and get the manual it should help
http://office.manualsonline.com/manuals/mfg/thermaltake_inc/thermaltake_inc_mouse_product_list.html
My Thermaltake Xaser keyboard lights
Firstly try replacing the batteries...
(2).if you can tab/mouse over to the accessibility option on the lock screen, select it and choose on-screen keyboard. Start clicking your letters now to log in and keep the on-screen keyboard open until you can get your computers keyboard fixed. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/nicole_525c14680d45ee5d
Thermaltake repair manual 500W
Do NOT Attempt to FIX ANY power supply yourself!!! If you touch the wrong thing inside the power supply you will die... Seriously! No Lie... Buy a New PSU...
Hey i resently got an (HP Envy H8-1414) And baught
You need to check the color, and order of the wires on all the connectors to make sure you don't short something out. Just because it fits doesn't mean it has the same configuration or voltage as the old power supply. This is especially true of the motherboard connector.
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Thermaltake TrR2-430W power supply won't power on
Try to unplug it from the motherboard and put a wire between black and green wire and see if the fan turn on if it won't turn on unplug all and open your PSU to see if the fuse isn't burned (ONLY IF THERE AREN'T WARRANTY)
They dont work when i
If it does not work at all:
Try moving it to another usb port.
Try moving it from a hub to the back usb connection
If the function keys don't work:
Try uninstalling the sowtware rebooting and reinstalling
