20 Most Recent Estate TS22AFXKQ Side by Side Refrigerator Questions & Answers
2answers
I HAVE THE ESTATE FRIDGE AND I CANT SEEM TO FIND
usually the filter is under the refrigerator side .open door look behind bottom panelor in frig compartment behund panel
6/20/2023 3:37:08 PM • Estate TS22AFXKQ... • Answered on Jun 20, 2023
Water continues to drip when glass is taken away. How do I fix it
Most likely the=> W10408179 Water Inlet Valve is defective and not closing all the way after use. I am here should you need me, Thanks John Tripp Appliance 911
4/12/2014 3:43:54 AM • Estate TS22AFXKQ... • Answered on Apr 12, 2014
Broken line in back of refrigerator.
We'll it shouldn't be anything too difficult and all you will need is a hose line the same diameter. You should be able to join it
1/5/2014 4:18:41 AM • Estate TS22AFXKQ... • Answered on Jan 05, 2014
What may cause the ice maker to just quit making
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/21/2011 2:39:53 AM • Estate TS22AFXKQ... • Answered on Sep 21, 2011
Temp control is set on
Hi
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:-
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
9/2/2011 6:51:35 PM • Estate TS22AFXKQ... • Answered on Sep 02, 2011
Broke
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
7/24/2011 12:57:02 AM • Estate TS22AFXKQ... • Answered on Jul 24, 2011
I've moved and when I
Were the doors removed in the move? If so, the electric connection and / or the water line connection for the water dispenser maybe disconnected. Is the filter in correctly? Is there any evidence the refrigerator leaks water? You said you know there is water to the valve, so you disconnected the water line, put the water line in a bucket, turned the water on and you filled the bucket right? You might have a problem with the water valve solenoids for both the ice maker and the water dispenser. Also, check for any kinks in the plastic water lines anywhere.
11/4/2010 6:17:29 PM • Estate TS22AFXKQ... • Answered on Nov 04, 2010
My ice maker is very slow
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
9/11/2010 11:28:50 PM • Estate TS22AFXKQ... • Answered on Sep 11, 2010
The refrigerator is running, but the freezer is
You have a bad compressor or a bad "clixon" switch. (switch that sends current to the compressor motor.) The clixon is generally mounted on the compressor and has the power wires going through it to the compressor. The starting capacitor could also keep the motor/compressor from starting You could use a professional at this point.
5/22/2010 2:27:34 PM • Estate TS22AFXKQ... • Answered on May 22, 2010
I fixed a kink in the water line, water filled the
Ok. here is the fix. warm up the frozen cubes with a blow dryer to get them out. Then dry off the area, keep the metal bar up so more water doesnt come in and slow you down. When the ice cube mold is dry spray it with PAM cooking spray, which is a safe lubricant in this application. Let the Pam dry for ten minutes and then turn your lever down. You will have cubes with in 24 hours or less and they will eject as they should.
7/7/2009 4:56:48 PM • Estate TS22AFXKQ... • Answered on Jul 07, 2009
Ice maker not making ice
Hi
If The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
3/29/2009 4:53:42 PM • Estate TS22AFXKQ... • Answered on Mar 29, 2009
Part no 100302
Could you check the part number to see if its correct. Haven't been able to find the part# to get an idea of what you need to assemble,
Your model number is TS22AFXKQ correct?
Thanks Sea Breeze
3/21/2009 3:51:52 AM • Estate TS22AFXKQ... • Answered on Mar 21, 2009
I have power and water to my ice maker and I can
May need to unplug the ice maker and take it out to look inside the cover. Use care as you open the metal cover behind the plastic cover on front because there is a spring that I don't want you to lose. Sometimes a little adjustment of micro-switch's inside will get it working. Look for stripped gear cogs and maybe missing a teeth. If your refrigerator is model TS22AFXKQ go to my web page and enter the model number in model parts search feature. You will get a couple models to chose from choose refrigerator. The diagrams on left of screen will show at bottom a parts breakdown of your ice maker. Click on link below [email protected]
http://servicepartstec.blogspot.com/
3/21/2009 3:38:04 AM • Estate TS22AFXKQ... • Answered on Mar 21, 2009
Can't find the drain on the freezer side of a ts25af estate refrigerator
found this.. https://www.youtube.com/watch?v=H_DKNtgd5vI If you have a Whirlpool, Maytag, KitchenAid, Roper, Estate or Kenmore defrostable refrigerator, that is leaking at its bottom and building up ice, you may have a plugged bottom drain line. This video will show you how to unclog this line. hope it helps.
1/21/2018 5:55:04 PM • Estate... • Answered on Jan 21, 2018
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains. you have pets? have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck call a PROFESSIONAL
1/3/2015 3:45:01 AM • Estate... • Answered on Jan 03, 2015
Refrigerators Logo
22 questions posted
Top Estate Refrigerators Experts
vince
Sean Wright
Sean Wright
MasterTech
MasterTech
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Estate Refrigerators
Most Popular Question
may cause ice maker just quit making
  • Refrigerators
