20 Most Recent
MTX Thunder TA7801 Car Audio Amplifier Questions & Answers
Can you bridge 2 4
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Overheating
the fans might not be running and if the fans are running then you need to keep the amp cool by letting it have access to the a/c or air from the windows. think of it like if you keep your body in a box for a long period of time and there is no air circulating then your body heats up same thing an amp need air circulating to stay cool.
Amp is a mtx 801d not sure
no you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
My amp doesn't turn on...
If there is a zero ohm connection across the B+ and ground terminals, it should blow the fuse as soon as you apply power.
MTX Thunder TA81001 amp
A large capacitor between your battery and the amp may help. Your alternator is most likely strained by the amp's power consumption. If you can't get a stronger alternator or suitable capacitor, you may nbeed to replace your battery and alternator more often than normal.
Amp is not coming on
the fuse may not be working, you could try a larger sized one, also if you have the old power cable try it again with a larger fuse in place, if it worked before its likely to just be the fuse wasnt big enough, check all the other connections are in the right place, if they all are and you know the amp hase worked before then it could only realy be the fuse isnt big enough or the power lead is faulty.
cheers, adam
