20 Most Recent Ohm Concept 12 Inch Dual 4 HZ Series Subwoofer Car Speaker Questions & Answers
Hi John, this CBR15 speaker model, is specified for real power handling 500 watts each speaker
If you connect the two Yamaha CBR15 in parallel, you will get an impedance of 4 ohms and an effective power handling capacity of 1000 watts, in this way you can apply that power, without risk of damage
I hope you serve my comment
Regards Franco Dosil
Hola John, este modelo de bafle CBR15, esta especificado para manejo de potencia real 500 watts cada bafle
Si conectas los dos Yamaha CBR15 en paralelo, obtendras una impedancia de 4 ohms y una capacidad de manejo de potencia efectiva de 1000 watts, de esta manera puedes aplicar esa potencia, sin riesgo de da?o
Espero te sirva mi comentario
Saludos Franco Dosil
https://mx.yamaha.com/files/download/other_assets/8/332498/cbr15_es_om_a0.pdf https://mx.yamaha.com/es/products/proaudio/speakers/cbr/index.html
Ohm Car Audio &... | Answered on Aug 21, 2019
dear sir, impedance matching between the amplifier and the speakers is very important. the total impedance will be 8 divided by 6=1.6666666 ohms , this impedance is not healthy for any amplifier, because the impedance must be between 4 ohms and 16 ohms
Ohm Car Audio &... | Answered on Sep 18, 2018
An amp that will handle 2 ohm stable as long as they are hooked up left and right. Try a fosgate or kicker amp. Just look up specs on the model you want.
Ohm Car Audio &... | Answered on Dec 07, 2016
Usually the amplifier is stable at 1 ohm or it is not. Usually not something you can change. If you are asking how to wire the speakers at 1 ohm that's a different question, but first you have to make sure your amp is 1 ohm stable of course.
Ohm Car Audio &... | Answered on Jun 25, 2016
Can you explain with a little more detail like does it have dual coils or single?
Ohm Car Audio &... | Answered on Apr 13, 2016
If your amp is the GT1-4500D, then no. The amp is only stable down to 1 ohm. Operation below 1 ohm load is not guaranteed.
Ohm Car Audio &... | Answered on Nov 04, 2015
If the subs you have are 2 ohm DVCs, that usually means each voice coil is 2 ohms. Putting the DVCs in parallel will make the sub 1 ohm, which is beyond the capability of the amp (which is only stable down to 2 ohms per channel). Putting each subs DVCs in series (for a total of 4 ohms per channel) will at least allow the amp to operate properly, even though you will not be able to maximize the output power.
http://www.interfireaudio.com/download/interfire_catalog_2009.pdf
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm.
If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms.
If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms.
If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced.
If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
Ohm Car Audio &... | Answered on Oct 28, 2015
Not again? Read this:
Speaker Impedance Explained Ohms
Ohm Car Audio &... | Answered on Apr 16, 2015
Since it is a mono block amp, it depends on your subwoofer (s), and how you wire them to the amp.
Single 4 ohm sub would be just that, 4 ohms.
Single dvc 4 ohm sub, with both voice coils wired parallel would be 2 ohms.
2 dvc 4 ohm subs wired parallel would be a 1 ohm load.
Ohm Car Audio &... | Answered on Feb 20, 2015
Make sure take voltmeter and test wires before you make any connections. In some modern (boats, cars etc) applications YELLOW is NEGATIVE (used to be memory).
Car Audio &... | Answered on Sep 16, 2020
Ohm Concept 12 Inch Dual 4 HZ Series Subwoofer Car Speaker Logo
Popular Tags
0 questions posted
Top Ohm Car Audio & Video Experts
Harrie
Steve Pack
Steve Pack
brian williams
Are you an Ohm Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Ohm Car Audio & Video
Most Popular Question
buy pair yamaha cbr15 speakers
  • Car Audio & Video
