20 Most Recent
Phoenix Gold Ti500.4 Car Audio Amplifier Questions & Answers
Phoenix Gold TI500.4
Your amp is either going into thermal protection mode or one or more of your speakers is shorting out.
Tryed to bridge
You probably blew the output transistors and if you did then the amp is as good as dead. Not worth it to fix just replace it.
My phoenix gold iron not heating up all blue lights flashing "need help please "
If your Phoenix Gold iron is not heating up and all the blue lights are flashing, it indicates a potential issue with the iron. Here are some troubleshooting steps you can try:
1. Check the power supply: Ensure that the iron is properly connected to a functioning power outlet. Make sure the power cord is securely plugged in and that there are no loose connections.
2. Allow the iron to cool down: If you have been using the iron continuously for an extended period, it may have reached its temperature limit and shut off for safety reasons. Let the iron cool down for a few minutes and then try turning it on again.
3. Clean the iron's soleplate: Over time, the soleplate can accumulate dirt, residue, or fabric fibers, which can affect the iron's heating performance. Make sure the iron is unplugged and cooled down before cleaning the soleplate. Use a damp cloth or sponge to gently wipe the soleplate and remove any debris. Avoid using abrasive materials that could scratch the surface.
4. Check the water tank: If your iron has a steam function, ensure that there is sufficient water in the tank. If the water level is low, refill the tank according to the manufacturer's instructions. A low water level can prevent the iron from heating properly.
5. Perform a reset: Some irons have a reset button or a combination of buttons that can be pressed to reset the device. Consult the user manual for your specific model to find out if it has a reset function and how to perform it.
6. Contact customer support: If the above steps do not resolve the issue, it is recommended to contact the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or advise on repairs or warranty options if necessary.
Always refer to the user manual provided with your Phoenix Gold iron for model-specific instructions and safety guidelines.
