20 Most Recent Phoenix Gold Ti600.2 Car Audio Amplifier Questions & Answers
how many watts is the amp and speker are you sure you are not putting too much?
Phoenix Gold... | Answered on Feb 02, 2008
Look up the part numbers on the components themselves. I can assure you that they are readily available from places not named PG. They are made in a factory with a bunch of diffenent Brands. If simply trying to repair the knob you may be able to use another knob from different Manufacturer if it takes the same jack for wire.
Phoenix Gold Car... | Answered on Apr 28, 2019
Probably the power is not received by the heating coil, check fuse near the power cable (inside the flap on the iron bottom), or sometimes there is fuse in the power pulg of the power chord. It is rarely that the lamp is blown
Phoenix Gold Car... | Answered on Jan 18, 2019
the entire schematic and owners manual can be found here:
http://narbi.free.fr/manuels/Amplis/Phoenix%20gold/M50.pdf
Phoenix Gold Car... | Answered on Sep 24, 2018
Most mono amps now a days give you multiple terminals. The older amps were a pain trying to stuff all the wires in one set of terminals. If the amp is rated at 2 ohms mono then make sure what ever configuration of speakers your running does not go below 2 ohms using both terminals. For example do not hook a 2 ohm load to each terminal. 2 ohms period between the 2 sets of terminals.
Phoenix Gold Car... | Answered on Feb 14, 2018
Check the voltage at the turn on lead into amp..use another switched power source .they sell relays for 5$...or another switched source...
Phoenix Gold Car... | Answered on Feb 17, 2015
Phoenix Gold Ti600.2 Car Audio Amplifier Logo
2 questions posted
Top Phoenix Gold Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
brian williams
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Phoenix Gold Car Audio & Video
Most Popular Question
interference
  • Car Audio & Video
