20 Most Recent
SVA-USA ED4218P 42 in. EDTV Plasma Television Questions & Answers
No picture on screen,the power
More than likely this will be down to your Y Sustain board has gone faulty, when the back is off your TV it is on the left hand side and will probbaly have a fuse that has blown, replacing the fuse will not solve the problem as it is the IMP under the heatsink that has gone faulty.
You should get the part number of the board from Ebay.com for a replacement.
Hope this helps
T V wont turn on
This is a common problem on these plasma TV's. The problemresides in the high voltage boards known as the X and Y Sustainboards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
We understand that your problem
some universal remotes are used only tv play.they did not open menu .so you bought original remote and solve your problem. thank you.
10/11/2010 8:06:53 PM •
SVA-USA...
Answered
on Oct 11, 2010
I have a small sva
With remote access the user menu and then Turn off the ' Closed Caption ' feature.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/16/2010 5:31:49 PM •
SVA-USA...
Answered
on Jun 16, 2010
