20 Most Recent TDV Vison F153 Monitor Questions & Answers
Hi. I have have repaird a few monitors, the acer one was the back light, but it was I think 7 capacitors, they were old, aged, and stopping the light from working. So, get it apart, and replace ALL the caps, they are not expensive, do not touch the parts when powered up, it is high voltage, and will probably hurt you whilst killing you, so, DONT TOUCH! Check out web for any other help, lots of videos to show you how to proceed. Ray.
TDV Vison F153... • Answered on Jan 02, 2018
Check all the cables, if it is not the cables being loose, then it is a component inside that is starting to fail.
TDV Vison F153... • Answered on Mar 19, 2017
It may have dying power supply due to bad caps, look for that first, may need more troubleshooting.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
TDV Vison F153... • Answered on Dec 13, 2010
go menu of front pannel of your tv and set
TDV Vison F153... • Answered on May 08, 2010
This is more specs then you can shake a stick at ;)
http://www.firingsquad.com/hw/5011/Vison_F153/?viewdesc=1
TDV Vison F153... • Answered on Jan 27, 2008
You may have to look for it under a different brand name. One way is to get the FCC number off the tag and look it up here: https://gullfoss2.fcc.gov/prod/oet/cf/eas/reports/GenericSearch.cfm That may show you a different manufacturer name and model number. Also, any info on the inverter itself can be useful. It may be made by Benq or Ambit, etc.
TDV Vison F153... • Answered on Jan 12, 2007
First of all make sure this is not just a button issue like having the BRIGHTNESS turned down too low. If you are unable to see anything including the menu screen items then the problem is probably not just a wrong display setting.
Turn on your monitor and then turn off all the lights in the room to check if your screen is completely black or if there is still a glow coming from it even though there is no video signal.
If your monitor screen stays completely black, then you most likely have a problem with the power supply to your backlight inverter circuit. This is normally caused by some failed electrolytic capacitors.
If you disassemble the unit and look on the power supply circuit board, you will probably see some scorched or bulging / leaking capacitors there. These components (usually around 6 of them) will need to be removed and replaced with new ones.
The repair procedure is not extremely difficult if you have some basic electrical safety knowledge, and some decent electronics repair / soldering skills.
You will need to unplug the power cord from the unit, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
Disconnect and remove the faulty circuit board. Desolder and remove the faulty capacitors and replace with new ones from your local or online electronic parts supplier. Then just reinstall / reconnect the board and test.
Here is a link to another Expert's solution to a similar problem which includes links to his excellent and informative set of LCD TV / MONITOR TROUBLESHOOTING GUIDES:
http://www.fixya.com/support/t10008425-when_turn_tv_picture_flicks_off
These guides will give you some idea of the various problems with LCD monitors and the associated repair procedures.
If you choose to rate BUDMRTN's troubleshooting tips by clicking on the YES THIS WAS HELPFUL icon on his solution page at the above link, then I thank you very much for your time and consideration.
Please comment back here to this page if you have any details to add, have any questions, have difficulty with the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
TDV Vison... • Answered on Aug 26, 2011
This sound like a bad capacitor ..-::>please click here and follow the guide.
TDV Vison... • Answered on Apr 21, 2011
could be the grahics card on your pc.
connect monitor to a laptop.
if there is not interference then its the pc video card.
TDV Vison... • Answered on Oct 16, 2010
Welcome to the world of disposable LCD monitors. I got one of these at Fry's, but have had no problem except that it won't accept HDMI input from my DVR.
Check the screen after it blacks using a flashlight to see if you can see the actual information displayed. The LCD is backlit with CCFL - cold cathode fluorescent light - tubes located at the sides or the top/bottom. They can go bad, and over draw the inverter, or the inverter, which converts ~12vdc to ~10,000Vac, can have capacitors which are low quality and are drying out, changing their value.
So, open the display up by un-snapping the plastic cover, removing the screws holding the metal support to the backside of the display, and then the back cover. Most have snap-together bezels that can be separated by using a thumbnail between the two pieces. You should then be able to inspect the power supply, inverter, and display logic board. Look for capacitors that have drooled or have their tops puffed up. Those are signs of failure.
Let me know what you find.
tom
TDV Vison... • Answered on Oct 11, 2010
Quickbooks Error 1334 occurs when you are trying to install, update, or repair the software program. It is one of the most common errors which you may face while you are using Quickbooks software. When this error encounters then an error message comes up which states that "Error 1344. Error writing to file. Verify that you have access to that directory." or "Error 1344. The file cannot be installed. Insert the Quickbooks CD and try to install it again".
Computers &... • Answered 33 minutes ago
Computers &... • Answered 34 minutes ago
I would try and reboot the computer and see if that solves the issue. If it still keeps on glitching and freezing after you have rebooted your computer It could also be the hard drive having problems or a bad CPU or bad memory or the power supply is starting to go bad or a hardware problem. Or a computer virus you should have your computer be looked at and repaired from a person that fixes computers.
Computers &... • Answered 11 hours ago
By Drive I'm assuming you are referring to a memory stick of some kind? Do you have another USB drive you could try. This will help find out if the issue is the USB drive or the computer. If the second USB drive does the same thing it's the computer causing the issue. If the second drive is OK your original drive has a problem. I could have gotten 'corrupted'. This is where the data stored isn't all there so it's confusing the computer when it's trying to read it. Try scanning it with an antivirus software to check there's nothing nasty hiding on there. Can you easily transfer data from your original drive once it is plugged in? How important is the data on the drive? You could try re-formatting it to 'clean' it. *NOTE* Re-formatting the drive will delete EVERYTHING stored on it.
TDV Vison F153 Monitor Logo
Popular Tags
18 questions posted
Top TDV Vison Computers & Internet Experts
k24674
Are you a TDV Vison Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • TDV Vison Computers & Internet
Most Popular Question
monitor flickering going blank
  • Computers & Internet
