20 Most Recent
Accelevision DVD Player with Built-in TV Tuner (DVD1008) Car Video Player Questions & Answers
I need to know the
If you look closely at the metal caps at the ends of the fuse you will see the voltage and amp rating of the fuse. You can then purchase a fuse with the same rating to replace the blown fuse.
The dome light stays on
(I'm assuming you mean the light on the unit)... chances are whomever installed it hooked the wire for the dome light up to constant/accessory by mistake or convenience... if there used to be a dome light in that location, all you have to do is drop it down and find the correct wire to tag, if there wasn't you will have to run one up from either you foot wells or another location or you can just put it to a switch. If you were referring to you factory dome light, it may be a broken door trigger, or a bad relay.
Yesterday I was driving down
Well this problem is caused due to the DVD stuck in the player, First of all you can please follow the below steps -
1. Unplug the DVD player (remove the power input wires from the battery) and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc. Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
