20 Most Recent Spidem Trevi Digital Coffee Maker, Espresso Machine Questions & Answers
you need to resubmit your question. the spelling error makes the question un answerable
Spidem Trevi... | Answered on Nov 05, 2014
There are 2 reset buttons on the side of the boiler if you have the neew J boiler.
If you machine is older, there is a reset button in the back of the boiler towards the bottom of the boiler. Push in between the 2 wires on the black thermostat on either boiler. Its harder on the J boiler because the thermostats are between the boiler and the side of the machine.
Spidem Trevi... | Answered on Apr 11, 2012
change thermostats
Spidem Trevi... | Answered on Feb 26, 2011
its bunged up with lime scale then,,,,,get some kettel cleaner mix it up in warm water in a jug,,,poor it in the water holder and let it run through ,,,catching it in the jug to return it to the water holder again,,do this a good fuw times till it runs freely,,then flush it out realy well with plenty of clean water before you drink from it
Spidem Trevi... | Answered on Jul 01, 2010
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Spidem Trevi... | Answered on Apr 18, 2010
Probably the Dump box, brew group, or drip tray not properly positioned or service door not closed.
So you can check one by one if they are in right position.
Good luck.
Spidem Trevi... | Answered on Apr 03, 2010
yes look threw saeco with that sup018m model #
Spidem Trevi... | Answered on Dec 17, 2009
Check the bottom of the container, there is a spring loaded valve and an o-ring, one of them might be damaged or not seated properly.
check saeco sites. for parts
Theres a internal valve that usally gets clogged with scale in such sonetimes a clean out will fix it
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Spidem Trevi... | Answered on Nov 20, 2009
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Spidem Trevi... | Answered on Nov 07, 2009
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Spidem Trevi... | Answered on Oct 23, 2009
Spidem Trevi Digital Coffee Maker, Espresso Machine Logo
Popular Tags
32 questions posted
Top Spidem Coffee Makers & Espresso Machines Experts
Pierre Laplante
graybeard32301
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Spidem Coffee Makers & Espresso...
  • Spidem Coffee Makers & Espresso...
Most Popular Question
digital display says overtemperature
  • Coffee Makers & Espresso Machines
