When you open to you're bios menu, either at the top or at the bottom of the screen will be a name of you'e bios. In you're case the name is at the bottom of your bios menu. (American Megatrends Inc.). Or for short AMI You could search google for, AMI bios beep codes.
And you can click on this link, which shows what AMI say's about 3 beeps.
http://www.bioscentral.com/beepcodes/amibeep.htm
You need to test you're memory. (Only if cleaning the memory has did not change the beep error beeps).
First remove you're memory & blow out the DIMM slots with canned air. Clean the copper on the memory with house hold alcohol on a lightly dampend cotton swab. (Let it dry), (Do not touch the copper with you're fingers. Re-install you're memory.
If you have more than one DIMM. Remove the bank farthest from the CPU & boot the PC. Did you hear the 3 beeps? Remove the the next bank & re-install the one you removed first in to the slot closest to the CPU. Boot the PC, again did you hear the 3 beeps?
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
