20 Most Recent Soundstorm 2000W MOSFET 4 Ch Amp w/Remote F4500 Car Audio Amplifier Questions & Answers
My amp just ?
add a bigger ground wire or move the ground wire to a new spot (make sure ground is bigger than power wire) or it could be fuse on amp but i think its a ground
3/4/2009 6:24:07 AM • Soundstorm 2000W... • Answered on Mar 04, 2009
Car system was working fine and now the sub
it could be the sub botten on the e.q or your hand change some settings on the deck or e.q.
3/2/2009 12:34:36 AM • Soundstorm 2000W... • Answered on Mar 02, 2009
My amp just stopped making sound
you mite have blown a speaker that would cause the amp to short and over heat and turn its self off. you also should make sure its not your deck
3/1/2009 1:53:59 PM • Soundstorm 2000W... • Answered on Mar 01, 2009
I HAVE A SOUNDSTORM SD960TS AND I DONT HAVE THE
My screen won't come out and when I get it out it's not on I did lose the face but every thing else works what do I do
5/23/2012 4:57:39 AM • Soundstorm Car... • Answered on May 23, 2012
0answers
Can a soundstorm F2500D handle a subwoofer
Hello sincere4140,
The Soundstorm is stable only to 2ohms.
Hope this helps.
7/29/2009 3:48:19 AM • Soundstorm Car... • Answered on Jul 29, 2009
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
12/5/2008 12:40:48 AM • Soundstorm Car... • Answered on Dec 05, 2008
2answers
Need the wiring diagram for
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
12/2/2021 5:04:03 AM • Car Audio &... • Answered on Dec 02, 2021
3answers
Need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
11/24/2021 11:08:04 PM • Car Audio &... • Answered on Nov 24, 2021
Ford focus 2011 aux button not working
This isn't an answer but my car is doing something similar. Every time I hit the aid button it goes to fm radio. I've tried doing what some these recommend but nothing is working.
11/22/2021 5:48:02 PM • Car Audio &... • Answered on Nov 22, 2021
3answers
I am out of prison and want to download music but i need a unlock code so i dont have to go through jpay to download music
Hello, Eric - Since your prison issued player is from JPay, you will need to arrange with JPay to have it unlocked for your use outside of prison. It will not work outside of prison now that you are no longer incarcerated. I suggest you contact JPay directly and ask about the procedure for having your prison issued player unlocked: https://blog.jpay.com/contact-us/ I believe you will need to send your tablet to JPay to have it unlocked and returned to you with the downloads you purchased and added to the player while incarcerated. Best wishes.
11/16/2021 2:19:12 PM • Car Audio &... • Answered on Nov 16, 2021
Soundstorm 2000W MOSFET 4 Ch Amp w/Remote F4500 Car Audio Amplifier Logo
3 questions posted
Top Soundstorm Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soundstorm Car Audio & Video
Most Popular Question
  • Car Audio & Video
