20 Most Recent Denon AVR-682 Receiver Questions & Answers
I cant connect my Denon avr 682 to my pc via optical??
I would change your setting on your receiver to digital. its probably on analog. look for a button that says that. You might have to change your input have a look at the rear and see if it says, DVD optical or CD and choose that input.
12/10/2012 3:11:24 AM • Denon AVR-682... • Answered on Dec 10, 2012
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
2/14/2010 10:06:17 PM • Denon AVR-682... • Answered on Feb 14, 2010
I am getting static out of all speakers in my
Static could mean a few things.
Magnets on or near (tube TV's) the system could disrupt the signal.
Try plugging the speakers in one at a time with music going to the AUX in. Run through all your settings to make sure that nothing is abnormal.
If it's plugged into a powerstrip, try plugging it into your wall outlet.
201-762-6500 is their main number.
11/17/2009 8:01:44 PM • Denon AVR-682... • Answered on Nov 17, 2009
I lost sound from my Denon AVR 682 last night.
Reseat all audio connectors sometimes they get dirty. Do you have surge protection? Do any other audio functions work? Clean your remote change the batteries the mute may be stuck. I vote for the battries being weak and the remote will not clearly send all signals.
8/19/2009 11:03:25 PM • Denon AVR-682... • Answered on Aug 19, 2009
Denon AVR-2807 w/ Hisense 4K 65A6H, audio issues
It sounds like there might be an issue with the HDMI handshake between the Denon AVR-2807 and the Hisense 4K 65A6H. Here are a few things you can try:
Check the HDMI settings on both the Denon AVR-2807 and the Hisense 4K 65A6H to make sure they are compatible with each other. Some HDMI settings such as HDCP, HDMI Control, and CEC can cause issues when they are not set correctly.
Try using a different HDMI cable. It's possible that the cable you are currently using is not compatible with the Hisense 4K 65A6H.
Update the firmware on the Denon AVR-2807. Sometimes firmware updates can fix compatibility issues with newer devices.
Try connecting the Hisense 4K 65A6H directly to the cable box and see if the sound works. If it does, then the issue is most likely with the Denon AVR-2807.
If all else fails, you may need to consider upgrading your Denon AVR-2807 to a newer model that is compatible with the Hisense 4K 65A6H.
I hope this helps!
3/20/2023 10:09:03 PM • Denon Audio... • Answered on Mar 20, 2023
2answers
Have a denon avr1312 setup is locked how do i unlock it
press and hold MENU for 3 sec or more. setup lock ON appears on the display. press > to change to OFF and press ENTER
3/20/2023 2:03:38 AM • Denon Audio... • Answered on Mar 20, 2023
2answers
Denon Receiver DRA-635R "Stereo" light on receiver constantly blinking. This occurs with all use: e.g. CD, Radio.
Due to the age of the North America/Canada model, I would check the power supply for stability.
3/16/2023 5:14:43 AM • Denon Audio... • Answered on Mar 16, 2023
Denon DNT 620. Does it burn CDs?
No it is only a player, not a burner.
Denon DN-T620 Operating Instructions Manual - ManualsLib
ManualsLib https://www.manualslib.com > ... > DN-T620 View and Download Denon DN-T620 operating instructions manual online. CD/cassette combi-deck. DN-T620 cassette player pdf manual download. ..
3/16/2023 5:08:01 AM • Denon Audio... • Answered on Mar 16, 2023
Denon av1550 short curcuit.
A 7805 is not a transistor, it is a voltage regulator and they rarely fail!
3/9/2023 11:03:27 AM • Denon Audio... • Answered on Mar 09, 2023
Denon AV1550 No Sound, No display. What part need to be check?
Power supply needs attention I would guess without working on it.
3/9/2023 7:55:46 AM • Denon Audio... • Answered on Mar 09, 2023
Where do you hook up a subwoofer on the avr 5800 denon
you do not. here is a link to manual copy and paste https://downloads.denon.com/documentmaster/us/avr5800_ownersmanual.pdf ..
3/1/2023 4:38:54 PM • Denon Audio... • Answered on Mar 01, 2023
I have a Denon AVR 3310CI everything appears to work HDMI inputs recognizes speakers but zero sound ???
If you have verified that the Denon AVR 3310CI is properly configured and connected to the speakers but are still unable to hear anything, you can try the following troubleshooting procedures: Examine the HDMI cables: Check to see that the HDMI cables are securely connected to the HDMI output port on your source device and the HDMI input ports on the receiver's back. To see if that resolves the issue, try substituting new HDMI cables. The microprocessor must be reset: The functions of the Denon AVR 3310CI are controlled by a microprocessor. Try powering the receiver back on while simultaneously holding down the "Power" and "Speaker A" buttons to reset the microprocessor. Check the settings for the sound: Check that the sound settings on the receiver are set up correctly. To ensure that the settings are optimized for your particular setup, check the model's manual. Aktualize the firmware: Check to see if the Denon AVR 3310CI's firmware can be updated. For additional information on how to update the firmware, you can visit the Denon website or get in touch with their customer support. Use a different source to test: To determine whether the issue is with the receiver or the original source device, test it with a different source device.
2/14/2023 2:20:54 PM • Denon Audio... • Answered on Feb 14, 2023
2answers
What is code for denon S760H for dish network remote
The code for the Denon S760H for a Dish Network remote is 0476. You can usually find the code listed in the manual for your remote, or you can search for the code online by typing in the model number of your receiver.
2/4/2023 8:22:24 AM • Denon Audio... • Answered on Feb 04, 2023
Denon DN-S3700 - Eject disc problem
you want expert opinion free LOL that does not happen .we are mostly diy fixers and do not get paid
1/30/2023 2:43:39 PM • Denon Audio... • Answered on Jan 30, 2023
3answers
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160 Ok..the procedure is easy. 1) unplug the unit and bring it to a well lit work area. 2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use. 3) re-install the board and plug in all the connections. 4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
12/30/2022 7:53:27 PM • Denon Audio... • Answered on Dec 30, 2022
3answers
I need to set up
Okay! all ceiling mounted speakers. I don't know about 4 pair of speakers.Here is the load down:
First pair of ceiling speakers would be left and right front from speaker A or Main output behind your receiver.
Second ONE,but a pair would be connect to the center channel output as your center speaker.
Another pair would be connect to the surround sound left and right(NOT surround BACK left/right.)
Now,you have 5 channel setup at this point,you still need to purchase a power subwoofer to the SUB PRE-OUTPUT behind your Denon receiver.
For Zone two,you would need to connect your other pair of speakers to surround BACK left and right output.
Go to your Denon MENU button,depending on which model you have,some of them will have an on-screen display feature(you would need to have a composite video cable connect from the video output behind your receiver to the TV video input in order to use the on screen menu.)If not,you would have to it view on the front panel of the A/V receiver.
You need to read the detail on how to setup the video and audio as well as distance and DB for the receiver through the menu button.
I will be frank with you,if you are an amateur,Denon is NOT easy to be setup on the first time.
solutiondoct
12/24/2022 11:55:00 AM • Denon Audio... • Answered on Dec 24, 2022
Denon AVR-X2400H Intermittent Protection Mode on startup
The clue I think is the fact the problem gets worse after being switched off. One cause could be leaking capacitors, the big ones in the the power supply. They hold a charge, but if they leak the charge is lost and they do that when the power is off. The only other I can think of is a voltage regulator. But I think that would blow a fuse. So I would get your guy to replace the caps.
12/19/2022 8:28:37 PM • Denon Audio... • Answered on Dec 19, 2022
Denon AVR-S540BT 5.2 Ch. 4K Ultra HD AV Receiver. How do I get the setup and use TV mode off of my receiver when I don't have a remote to do it?
Question edited for clarity, full 'make model (what it is)'. Question moved to maker category. You can't. All devices that have a remote need it. You can get a new one here for $11 at Walmart. https://www.google.com/search?q=avr+s540bt+replacement+remote+control ..
11/4/2022 5:44:17 PM • Denon Audio... • Answered on Nov 04, 2022
Denon AVR-682 Receiver Logo
11 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
connect denon avr 682 pc via optical
  • Audio Players & Recorders
