20 Most Recent Visonik VB-10PKG Car Audio Amplifier Questions & Answers
im sry about that but i got one right here an visoniks arent that bad of a amp but for ur high input u will have one next to one another left to right is + - then under that is the same u can only hook up four speacker to the one i got . i hope this helps if so please votes
Visonik VB-10PKG... • Answered on Jul 19, 2011
make sure you have the remote wire plugged in really good its the blue one coming out of the amp
also make sure its plugged into the right wire from the back of the stereo the remote wire and the antenna wire are almost identical but the antenna wire should have a little white on it
Visonik VB-10PKG... • Answered on May 13, 2009
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Visonik VB-10PKG... • Answered on Mar 29, 2009
Make sure your gain is turned all the way down. Unplug the RCA cables before hand. What does the subwoofer do when the amp powers on?
Visonik VB-10PKG... • Answered on Feb 08, 2009
This usually involves removing the plastic bezel around the stereo. Sometimes these plastic bezels hold some buttons for air conditioning and heat, as well as the hazard lights button. These plastic bezels usually are just snapped in with metal clips on the back of them. You can pry them outward and with a good yank they will pop out. Once you have the plastic bezel around the radio removed, there will be 2-4 screws on the sides, or top and bottom. Once you remove those, the whole radio will pull right out of the dash. Then you have to un-clip the wire harness from the car, and unplug the antenna cable. If you plan on putting a different stereo in the car, KEEP the mounting bracket around the stereo, as well as the "wiring harness" that was used to plug into the vehicle harness. That will save you about $50 in parts to put a new stereo in.
Visonik Car... • Answered on Aug 23, 2016
To be absolutely sure of which terminal is positive and which is negative, we will use a 1.5 v battery to have the speaker react as though it is playing music.
* special note * do not use any more than 1.5 v as it may damage the speaker coil
As we know, batteries are marked positive, negative, or both ... we will use this to our advantage when hooking up the battery to our speaker.
To start the process, temporarily attach a short piece of wire to each terminal of the speaker (be sure to either use wire that is marked, or wire of differing colours to help determine which terminal is which). In our example, we used standard speaker wire which is "polarized" (one wire is made of copper and the other is made from tin .. interestingly, this serves no electrical purpose)
Once you have connected the wire to your speaker, proceed to briefly touch the free ends of the wire to the battery terminals (as shown below). In some cases, extended contact with the battery has caused cancer of the voice coil (ie. blown speaker)
If the speaker moves OUT when the battery is first connected, the battery is connected in proper alignment. Be sure to take note of which wire is connected to the positive terminal of the battery as this is your speaker's positive terminal.
Visonik Car... • Answered on Aug 18, 2012
Visonik VB-10PKG Car Audio Amplifier Logo
6 questions posted
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Visonik Car Audio & Video
Most Popular Question
need wiring instructions vbx12a
  • Car Audio & Video
