20 Most Recent Marvel (6SBARBSG) Wine Cooler Questions & Answers
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Marvel... | Answered on Jul 03, 2018
Don't know, but their should be a label on or near the compressor that tells you.
Marvel... | Answered on Mar 01, 2015
www.marvelrefrigeration.com
Marvel... | Answered on Jun 30, 2014
I truly doubt the control is the faulty component. It has two inputs it uses to decide when to cycle the compressor.
1) the potentiometer with the control dial is connected to terminals # 6 and 7.
2) the thermsitor is connected to terminals # 4 and 5.
Most of the time it is the thermistor that has failed. Marvel Part number 42244531.
You can order it directly from the factory by calling 800-428-6644
Marvel... | Answered on Dec 16, 2013
Are you looking for instructions how to replace the stat, where you can get one or who can do it for you?
With either question I would need to know the full model/serial number.
If it was made before 2001 it will have an electric-mechanical stat which to my knowledge may no-longer be available. The electronic stat used 2001 to 2007/8 is still available as well as an upgrade kit to replace the old style. You can call the factory at 800-223-3900 and ask for customer service. Ask for Tim Malloy or Ron Peterson. They will know if they still have the old style stat (easier to replace and cheaper) or if you require the SSAC control or the upgrade kit. Make sure you have the full model/serial number when you call. If you cannot locate the serial number reply back and I'll give you guidance how to determine which control you have.
The factory can also refer you to a servicer in your area. If you need to do it yourself, reply back with what control you have and what you purchased and I'll help you get it installed correctly. Good-luck, Subdriver
Marvel... | Answered on May 07, 2013
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Marvel... | Answered on Jun 11, 2011
Yes, you can purchase a new thermostat from the factory by calling 800-223-3900. Since your unit was built during the year they were switching from electro-mechanical to solid state you will need to know which one you have when you call. They can help you determine which one it is. The electro-mechanical will have an aluminum sensing line exiting the back of the stat (connected to the temperature control dial) and two individual wires. (may also have a green ground). The solid state consists of three parts: Control Board (located in the rear near the compressor), thermistor (located on the right side of the evaporator plate and connected to terminals 4 and 5 of the control board) and potentiometer (attached to the control knob and has wires connected to terminals 6 and 7 of the control board). You most likely have the solid state control.
I hope this helps.
Marvel... | Answered on May 26, 2011
Hello Doneegans,
I understand that you are hearing a bad noise coming from your Marvel WIne Cooler. There are only two things that can be making this noise in your unit they are the compressor and the evaporator fan. I am would think it was the fan as you are not experiencing any problems with the temperature.
If you can please post the model of your unit becasue there are so many different units I would gladly locate you the fan and explain how to change it on your unit. Please post back to this thread.
Thank you for choosing FixYa.com
Justinbur167
Marvel... | Answered on May 23, 2011
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Marvel... | Answered on May 06, 2011
Marvel (6SBARBSG) Wine Cooler Logo
54 questions posted
Top Marvel Furniture Experts
Jim
john h
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
View Most Popular
Marvel Furniture
  • Marvel Furniture
Most Popular Question
not cooling frosting up upper right
  • Furniture
