20 Most Recent
Yamaha iiyama 17NE1-S e-yama 17" LCD Monitor Questions & Answers
E-yama monitor "out of range"
The fix was pretty easy in the end.
Instructions are based upon Windows XP Pro OS.
Re-boot computer but inerrupt start-up by pressing F8 (option will vary between computers)
Select SAFE mode but with VGA option in order that the screen will actually display.
Once fully loaded click:
Start
Control Panel
Appearance and Themes
Display
Settings
Using the mouse cursor adjust Screen Resolution sliding scale until the ratio matches your monitor e.g. 1280 x 1084
Then click Apply and OK (important to do it in this order otherwise changes will not be saved)
Reboot as normal and the monitor should now display correctly.
Yamaha iiyama...
Answered
on Nov 10, 2009
Screen keeps fading
I don't know for sure if this will help but it's worth a try. Go to Start, control pannel, system, advanced, performance, settings, and click adjust for best performance. This is a Windows XP fix but the same thing may apply to older OS's (95, 98, 2000, ME, NT (although you may have to set it a diferent way). Many other things could be your problem but this is an easy thing to try.
Yamaha iiyama...
Answered
on Sep 12, 2009
How do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Yamaha Computers...
Answered
on Jul 29, 2019
Tyros 1 cutting out screen goes grey and restarts
Guessing that some people think a Tyros 1 is a PC or something.
If the Tyros goes blank screen and all the lights go out then it is most likely the REG board (regulators) that provide the 5v and 3.3v. This overheats and the devices shutdown. Quite often this is cured with a restart on more serious cases the regulators need replacing. As they are cheep it is best to replace all while the unit is apart. I am just about to do this repair on a Tyros I purchased the other day.
Computers &...
Answered
on Jul 27, 2019
Yamaha AW4416 retrieved from long time storage hangs up on initializing recorder message when booted. Suspect flat battery in RTC chip?
AW4416 Users - HELP needed!
I think my hard drive crashed or is in trauma! It 'froze up' so I shut it down. When I try to restart it it never gets past the "Initializing the Recorder Section" window. The HD's red light is on without any intermittent blinking.
Is there a trick to get it to boot up so I can back some stuff up?
Last year when I had lots of stuff on the HD I had occasional freeze-ups but it always came back. Then when that project was finished I got all of it off the HD into a backup and the AW has been smooth for more than a year. Recorded a CD for a local string Quartet and everything was good. When that wrapped up I wiped the HD again and started a CD for myself. Not a lot of songs or tracks yet but some stuff I really don't want to lose if possible.
Hard lesson to learn.
Bill from PA, are you out there? any other AW4416 users?
the AW user forum (socialentropy.com) seems dead! I've gotten some great help there!
Thanks
Sourov
Yamaha Computers...
Answered
on Jan 15, 2019
BlueRay to Yamaha RX-V563
Did it ever work? Have you tried more than one input on the Yamaha? Will the BlueRay play through a different system? Seems unlikely that both the L & R cables are bad. If it's an optical cable, have you ruled out a bad cable?
Yamaha Computers...
Answered
on Feb 25, 2018
