20 Most Recent Denon AVR-2803 Receiver Questions & Answers
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?Thank you.
1/17/2017 7:04:02 AM • Denon AVR-2803... • Answered on Jan 17, 2017
I can't seem to get the tuner to work on my Denon AVR 2803 receiver.
It can't hurt. You will lose all your settings though. So you'll have to set the amp up again from scratch. Before you do initialise, let's just check.... You plugged in a FM or AM aerial, right?
9/14/2014 9:14:55 PM • Denon AVR-2803... • Answered on Sep 14, 2014
Lack of true bass
LFE out may be selectable between subwoofer, main, or both. If it's set to subwoofer, then the front speakers won't get any low frequencies sent to them.
2/26/2013 7:57:24 PM • Denon AVR-2803... • Answered on Feb 26, 2013
0answers
Power cut
Be the first to answer 11/19/2012 2:17:43 AM • Denon AVR-2803... • Posted on Nov 19, 2012Be the first to answer
2answers
Denon AVR-2803 Zone 2 sound source
You have to switch your remote into Zone 2 Mode. It will be an option on your remote. Once you put it in that mode, you can change the source just as you would Zone one.
7/20/2012 4:15:34 PM • Denon AVR-2803... • Answered on Jul 20, 2012
2answers
Denon avr 2803 relay
Here is the Denon product support page it appears that you can get parts from their parts and repair network. hope this helps.http://usa.denon.com/US/Support/Pages/ServiceCenterLocator.aspx
6/1/2012 11:03:33 AM • Denon AVR-2803... • Answered on Jun 01, 2012
I have a Denon AVR
The optical audio connection (the TOSLINK) only works when paired with the Component connectors. Now you are using the the Composite one so you must use the audio connectors associated with it, the red and white next to it; then select the VCR1 input when you want to use them.
The audio quality will suffer a little but it will most surely pass unnoticed in most of the cases.
8/16/2011 2:06:03 PM • Denon AVR-2803... • Answered on Aug 16, 2011
Hi, some troubles with my DENON
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
8/3/2011 9:22:54 AM • Denon AVR-2803... • Answered on Aug 03, 2011
AVR-2803/983: Had recent 24hr
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
7/16/2011 2:29:03 AM • Denon AVR-2803... • Answered on Jul 16, 2011
I've got a Denon AVR
Hi, and yes there is hope, there's a saying that when something is tedious and or boring to read "it reads like stereo instructions ".The first thing to make sure of is you have a rather stiff connecting cable called a "TOSLINK" cable this has squarish ends and plugs into the "DIGITAL AUDIO OUTPUT" of the x-box 360 and then plug the other end into whichever input your using for the x-box. A dead giveaway to the jack to use on x-box is that it may actually be lit up red while playing. it also may be labeled "PCM/LPCM" versus digital audio. Anyway that should get you your surround sound on your stereo. Thanks for choosing FixYa, Let us know if there's anything else we can help with,and good luck, Prodzilla
4/14/2011 1:08:36 AM • Denon AVR-2803... • Answered on Apr 14, 2011
0answers
I have an AVR-2803.. recently,
Heat.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
2/1/2011 10:27:25 AM • Denon AVR-2803... • Answered on Feb 01, 2011
Hi, just connected a Blu Ray player to my sytem.
We can't make assumptions about proper and complete setup if you don't explicitly mention the steps involved, so... did you assign and select the digital inputs properly?
http://www.retrevo.com/s/Denon-AVR-2803-Receivers-review-manual/id/363bh829/t/1-2/
Page 23 etc
BTW: I concur with your decision to send the video directly to the TV from the BD even though Denon and others expect it to make a hop through the receiver first.
Get into your BD and find its audio out setup. Make sure its settings for digital audio output bit rates, speaker presence, type, size, distance and bass-handling are set correctly.
1/31/2011 1:08:08 AM • Denon AVR-2803... • Answered on Jan 31, 2011
Recieving audio but not receiving
if your usin the 3 connector rca cables make sure you have the yellow wire connecte to the video input that corressponds to the audio input your using then run a video cable from the video output to the tv. then make sure your on the correct channel. or you can just run the coax from the cable box to the tv with just an audio cable from the cable box to the sterao.
1/30/2011 12:52:49 AM • Denon AVR-2803... • Answered on Jan 30, 2011
I have just replaced non functioning DVD player
If you want the best viewing from the DVD-R just run its HDMI straight to the TV and its best digital audio to the Denon. Why do you NEED DVD-R video at the receiver?
12/29/2010 12:35:16 AM • Denon AVR-2803... • Answered on Dec 29, 2010
looks like you are overheating it let it cool down for at least 20 min. and then when you use it just lower the volume, after that it should give you no more troble
12/19/2009 7:11:15 PM • Denon AVR-2803... • Answered on Dec 19, 2009
Denon AVR-2803 Receiver Logo
40 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
seem get tuner work denon avr 2803
  • Audio Players & Recorders
