If you are using a USB mouse and keyboard then the most likely problem is a failed USB controller on the motherboard. And as your motherboard is old and was never very popular you will be hard pushed to find a replacement. Although you could try fitting a PCI USB card to use your input devices. It looks as if you will need a new motherboard, processor and RAM.
If you are trying to install Windows XP then - The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
The wired mouse is more responsive for that exact reason, it's connected by a wire. The cheaper bluetooth wireless setups can have poorer quality parts in them so it won't connect as well as a brand name wireless mouse. Try plugging the receiver into a different USB port. Some ports are set up for faster connection. It might be marked with an "SS" or the spacer in the port hole will be coloured blue. You could also check and update the software 'drivers' to see if that helps.
Phone your Internet Provider that you require their newest Home Hub and engineer to install it and check the cable / phone connections to your home. Tell them the service is terrible and if they don't fix it, you are changing companies. In the last 20 years, I have had 4 upgrades of routers.It is not you or your devices, it is the equipment from your ISP or the cables that supply that service...
The issue with the Vaddio ProductionVIEW 999-5700-000 where both Control A and Control B lights are on during boot, resulting in a loss of camera control, may be sporadic and hard to recreate intentionally. It could indicate intermittent hardware or firmware issues. To address this:Ensure all connections and cables are secure.Check for any firmware updates or patches provided by Vaddio to address potential bugs.If the problem persists, consider contacting Vaddio's customer support for specific diagnostics and potential solutions, as this issue might require specialized technical expertise.
Freeviewhttps://www.freeview.co.uk > tv-guide
The biggest shows live and on demand all for free with Freeview Play. find out more · BBC ONE Lon. Series 23: 40. Devon and Dorset. Escape to the Country · BBC ...
TVGuidehttps://www.tvguide.co.uk > mobile
TV Guide for all UK channels including Sky, Freeview, Virgin and Netflix. See what's on TV now and next and search for your favourite shows.
Please use Geeksquad to help transfer your data from that hard drive before throwing it away. If it's malfunctioning now, you're not going to want to store anymore data on it.
Thank you.
Cloud computing is the delivery of computing services via the internet rather than through local servers or personal devices. Servers, storage, databases, networking, software, analytics, and intelligence are all examples of computing services. These services are transferred outside of an organization's firewall and are available over the internet. Cloud computing reduces operating expenses and enables efficient scaling because consumers pay on an as-needed or pay-per-use basis.
As Cloud Computing is a buzzword in the IT industry, If you want to pursue a career in Cloud Computing then you can go for a Cloud Computing Course.
CHARACTERISTICS OF CLOUD COMPUTING
According to the National Institute of Standards and Technology (NIST), all true cloud environments have five key characteristics:
On-demand self-service: Cloud customers can easily sign up for, pay for, and begin using cloud resources without the assistance of a sales professional.
Customers can access cloud services through a wide network, such as the internet.
Resource pooling occurs when multiple types of consumers (individuals, organisations, or departments within an organisation) use the same servers, storage, or other computing resources.
Rapid flexibility or expansion: Cloud users can simply scale up or down their utilisation of resources as their needs change.
Measured service: Instead of purchasing hardware or software up ahead, customers pay for the amount of resources they use in a certain period of time. (It should be noted that in a private cloud, this metered service usually entails some type of chargebacks in which IT keeps track of how much resources different departments within an organisation use.)
Resource pooling occurs when multiple types of consumers (individuals, organizations, or departments within an organization) use the same servers, storage, or other computing resources.
Rapid flexibility or expansion: Cloud users can simply scale up or down their utilization of resources as their needs change.
Measured service: Instead of purchasing hardware or software up ahead, customers pay for the number of resources they use in a certain period of time. (It should be noted that in a private cloud, this metered service usually entails some type of chargebacks in which IT keeps track of how many resources different departments within an organization use.)
Contact Support. 'Protection Off', means that it is turned off and not protecting you. Do you also have Windows Defender active on the machine? Windows may have turned the competitor off, or your subscription has expired.
https://www.glarysoft.com > malware-hunter > download
Malware Hunter is an award-winning product that provides comprehensive protection against all types of threats, secures your data, protects your privacy and ...
Operating System: Designed for Windows XP/...
Release Date: Sep. 07, 2021
File Size: 80.67 MB
If it as a dual bios chip, restore from the older bios to overcome issues.
The only place the bios updates are available is from the manufacturers web site, if available.
my guess is this software is infected.
no source stated, URL
and you did not run VIRUSTOTAL.com on the install file first.
you will learn from this mistake.
1: only get games from maker or STEAM
2: run AV virustotal.com free on the installer.
3: set restore point in W10
4: load the game and pray.
or use , REvo uninstaller, and run it and pick Install the game. now it will remove it later if bad..by the roots.
