20 Most Recent Denon AVR-1905 Receiver Questions & Answers
HOW TO UPDATE THE FIRMWARE
There may not be any facility to update the firmware for this model without taking to the service center. This model does not have any device input like SD card or internet connection that would enable download of firmware upgrade. The later Denon models have this capability. You will have to consult the local Denon service center for advise.
3/16/2015 10:04:13 AM • Denon AVR-1905... • Answered on Mar 16, 2015
My denon 1905/785 receiver stopped working on zone
Try a reset to factory defaults and reprogramming your preferences. Time consuming, but sometimes things go bung inside the microprocessor controllers.
12/10/2013 12:21:47 PM • Denon AVR-1905... • Answered on Dec 10, 2013
0answers
Receiver blowing fuses
Problem is most likely shorted output transistors. These are the large transistors mounted on the heatsink. When these go short, they usually take out some the adjoining resistors in that channel.
8/1/2013 7:56:19 AM • Denon AVR-1905... • Answered on Aug 01, 2013
0answers
When i power on the device, it comes on but goes off about 5 seconds later.
Hi...
1st thing to check is for GOOD speaker connections at both ends
and not mixing A and B speaker wiring.
A Denon is usually a good brand. Might be worth servicing if need be.
4/21/2013 5:03:16 AM • Denon AVR-1905... • Answered on Apr 21, 2013
2answers
i would check the output ic/transisters
10/8/2012 6:54:54 PM • Denon AVR-1905... • Answered on Oct 08, 2012
Manual
3/12/2012 10:16:59 PM • Denon AVR-1905... • Answered on Mar 12, 2012
Blinking red light
there is a blown channel or bad power supply in your receiver.
10/27/2011 12:56:26 PM • Denon AVR-1905... • Answered on Oct 27, 2011
My Denon AVR1508 receiver wont
setup > option setup> then change -20db limit to limit OFF
9/28/2011 4:12:05 AM • Denon AVR-1905... • Answered on Sep 28, 2011
Hi, I have a Denon
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
9/22/2011 1:39:28 PM • Denon AVR-1905... • Answered on Sep 22, 2011
0answers
I have a Denon AVR 1905 stereo receiver. It turns
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
7/7/2011 7:21:16 PM • Denon AVR-1905... • Answered on Jul 07, 2011
Can i bi-wire the front left and right speakers
Not with this unit.
But WHY? Bi-wiring is a myth. Whether the channel's double wires join (dead short) at the amp end or the speaker end makes no electrical difference to the speaker or the sound. But it DOES get you to buy more esoteric wire. Cha-ching for them!!!
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/audio/biwire/Page1.html
http://www.avforums.com/forums/interconnects-speaker-cables-switches/46335-bi-wiring-cables-what-load-long.html
But to flip an old saying, believing is seeing (or hearing). Go for it if you want. Someone is always willing to take your money.
5/20/2011 4:20:01 PM • Denon AVR-1905... • Answered on May 20, 2011
It appears that the protection circut has
When you turn on the Receiver if after 4 seconds you hear a click and the standby light starts blinking - it indicates an output short circuit. You will need professional help to replace the components because modern AV receivers have very complex construction ( multiple circuit boards mounted on one motherboard and a lot of interconnecting cables )
4/19/2011 2:49:55 AM • Denon AVR-1905... • Answered on Apr 19, 2011
Denon AVR-1905 Receiver Logo
61 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
Morne Olivier
Morne Olivier
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
receiver blowing fuses
  • Audio Players & Recorders
