20 Most Recent
Scotsman Ice Maker WBin Flake Style water cooled self c Questions & Answers
SCOTSMAN MODEL #CME506WS1F
You need to descale the water circuit according to manufactures instructions. Scale build up keeps the ice from releasing during harvest cycle. If overall ice thickness is to thick, rotate the ice bridge thickness screw at the top of the platen countercloclwise about 1/8 of a turn max between freeze cycles until desired thickness obtained. If you do not know the correct descale solution alway use a nickel safe descaling solution.
The model for Scotsman ice maker is AFE400A-1B and
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Banging noise in water line
If it is banging after it shuts off or cycles you may have a noisy compressor.It can happen during a move or if it droped.Hope i helped:)
I have a I have a Scotsman SCCP30MA that stopped dropping ice . I have unit defrosted and cleaned. What can I do to check that things are functioning as they should? Please help. Thanks.
To check if the ice maker in your Scotsman SCCP30MA is functioning properly, you can try the following steps:
- Ensure that the ice maker's water supply is turned on and that the water line is not clogged or frozen.
- Check the thermostat settings to ensure that the freezer is at the proper temperature.
- Inspect the water inlet valve to make sure it is not clogged or defective.
- Check the ice maker's control arm to make sure it is in the correct position and not blocked.
- Inspect the ice maker's ejector blades to ensure they are not clogged or damaged.
- If the above steps do not resolve the issue, the problem may be with the ice maker's control module or motor, which would require professional repair or replacement.
It's also important to check your machine's manual, as it may have additional troubleshooting steps specific to your model.
1/22/2023 6:07:06 PM •
Scotsman...
Answered
on Jan 22, 2023
Hi my scotsman mv 450 only makes 150kg in 24 hour cycle and not 215kg
how old is it? when was the last time u had pm done?
have a qualified hvac/refrig tec come do a pm and you will know.
they will check voltages/amperages, pressures, valves timers etc.
trust me, this is your only answer (unless you have it in a location that encloses it in a 100 degree room without ventilation.
get proper pm service done.
1/3/2015 3:16:24 AM •
Scotsman...
Answered
on Jan 03, 2015
Can t get scotsman cme1656rs to start
problem was not the universal controller. The bin sensors are dirty and scaled up and gives the same indication that bin is full. find the sensors and clean the scale off and unit should start working again. Save the card, you will sooner or later probablly need it.
10/1/2014 12:46:52 AM •
Scotsman...
Answered
on Oct 01, 2014
Water diagnostic code
I do not have enough of your water diagnostic code, but the normal cause is the dual temperatur probe, if the sensor that is inserted just downstream of the water pump is bad and doesnot sense the temperature change as the water cools the unit senses this as a water pump problem and stops the freeze cycle but shutting down and giving a water code. PS I use to know a guy on the USS George Bancroft before 1980 named DJ White. If you were this guy I still have your ship's plaque if you want it.
Joe Abbey
10/1/2014 12:21:31 AM •
Scotsman...
Answered
on Oct 01, 2014
Bin full light
The sensor build limestone residue during operation and needs to be cleaned off. The bin sensors are typically located on either side of the freeze platens and can be removed to clean. Turn machine off and unplug. Reach in past the water trough and freeze platen and you will see the transmiter and receiver plugged into the side walls. Gentlely work sensor loose and work sensor wiring out hole until you can get to sensors. Clean the two sensor with a clean cloth and with vinegar until sensers are clean. Reinstall, and plug back in and start unit. Bin sensor light should be out and should start.
10/1/2014 12:10:18 AM •
Scotsman...
Answered
on Oct 01, 2014
My Scotsman 275 is giving me a refrigeration error
If the water pump is not working, or working intermittenly, it is the first thing I would replace. Often causes for water pump failure is bearing/bushing failure and excessive limeston buildup. As for as the refrigeration error, there is a dual probe sensor that inputs temperature into the control card for the discharge temperature of the compressor and the water pump discharge temperature. You can check to see if each of these device are function with a ohmmeter and see if the resistance is 10k - 15k ohms. If either of these do not check out, it needs replaced. Next see if the condenser is dirty, excessive freeze times can cause refrigeration error due to excessively long freeze time (freeze times >60 minutes). If dirty, clean coil until you can see light through the coils. During the operation, check to see if the fan runs continously during freeze cycle. If it starts and stops or just stops, fan motor needs replaced. Any thing more will require an ice machine tech to troubleshoot with his instruments. Hope this helps a little.
10/1/2014 12:01:49 AM •
Scotsman...
Answered
on Oct 01, 2014
Scotsman ice machine continuous water flow
If you have a continuous flow during operation you need to replace the supply water solenoid valve. These valve are available at most cc dickson supply houses or through your local refrigeration tech. They will need you model number.
9/30/2014 12:55:16 AM •
Scotsman...
Answered
on Sep 30, 2014
