20 Most Recent
Abit VT7 Motherboard Questions & Answers
HOW TO CLEAR CMOS ON ABIT VT7
on your board it will say cmos pin 1 and 2 are closed make sure that your computer is off then put the jumper on 2 and 3 turn it on then turn off computer then put the jumper back to pin 1 and2 then startup compter
5/23/2014 5:27:51 AM •
Abit VT7...
Answered
on May 23, 2014
How to reset bios
take out the battery ? (also make sure computer is unplugged. Leave it like that for 10seconds plug in battery , plug in mains.
5/13/2012 10:24:53 AM •
Abit VT7...
Answered
on May 13, 2012
I have an Abit VT7
Check if your Ram is inserted properly or remove and reinsert it properly.Thank you.
9/2/2011 12:33:44 AM •
Abit VT7...
Answered
on Sep 02, 2011
I was cleaning out the
take cards out and clean make sure there fully inserted into slots and fixed,then try it again
8/21/2011 10:25:37 AM •
Abit VT7...
Answered
on Aug 21, 2011
Hello
i have a windows
XP can't be installed in SATA drives because it doesn't have a generic driver for them. Begin the install and during the procedure you will be asked to press F6 to install extra drivers - do just that with the driver that came on a floppy.
10/4/2010 2:41:47 PM •
Abit VT7...
Answered
on Oct 04, 2010
Canot instal ati hd 2400 graphic card on xp profesional sp3
I am a Nvidia man myself but have had this same problem with other peoples systems. Make sure you have the correct version of Microsoft .net Framework installed on your system before installing the video driver. Check ATI driver download page for .net Framework requirements for this paticular driver package.
1/6/2009 6:37:08 PM •
Abit VT7...
Answered
on Jan 06, 2009
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
Kds monitors support
Hi Klex,
I was able to find the website address
www.kdsusa.com through one of their products on Newegg, but the site appears to no longer exist. They also had a phone number listed (1-800-283-131) but that too doesn't seem to work. I have the feeling that they have either close their business or ended their operations in the U.S..
Sorry I didn't have better information for you.
