Daca asta e placa (sau e similara) atunci asta e driverul
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?langid=1&pfid=24&level=4&conn=3&downtypeid=3
Hello hosamali , As you say you have no sound on computer. here is full solution of sound and sound card.... First,
test your speakers by connecting them to another sound device like
CD/DVD player or a similar device. If you can hear sounds from the
speakers, they are fine. Next, connect the speakers back to the
computer. Make sure that you plug them into the right colored jack at
the back. The speaker pin should be plugged into the green jack at the
back of the computer.
Now, if you can't see the speaker icon in
the system tray, you may need to enable it from the Control Panel. From
the Control Panel, double-click "Sound and Audio Devices" and check the
box that says "Place volume icon in the task bar.
Next, run the following command from the Start -> Run box and then press Enter: dxdiag
Click on the Sound tab and you can see the details of your sound card.
You can also test your sound card from this tab. Note the name of the
sound card driver, on paper. If you can't even see the sound driver
name, the driver is not installed or not installed properly.
The easiest thing that you can do now is to do a system restore, using the System Restore utility.
or simply type your motherboard name on Google search and download
If System Restore didn't make the sound work, do the following:
Start
the Device Manager (Right-click My Computer -> Properties ->
Hardware -> Device Manager) In Device Manager, Click the + sign next
to "Sound, video and game controllers". See that the sound driver that
you noted above, is listed.
Now, double click the item in that
list that has the same name as you saw in dxdiag's sound tab. Does
Device Manager say that the device is working properly? If Device
Manager says that the audio device is not working properly, or if there
is a yellow exclamation mark next to the device, or if it says that the
drivers are not installed for this device, install the drivers from the CD or from the computer manufacturer's website. However, there's an
easier way to do this, as given below.
Here's the easy way to get or update your sound drivers: You
could try to use this driver scanning tool, which scans the computer
for needed drivers and has an option to automatically retrieve them for
you.
After
you have downloaded the above file, double-click on it and follow the
simple steps to install it. Then, when it asks if you want to run it,
just answer yes. This is easier than manually searching, downloading and
installing the drivers.
It's also possible that the drivers are
there but the sound card was displaced a bit from it's slot (in case you
have a separate sound card on your motherboard, and not a built-in
one).
If you suspect this, you should open up the computer and
pull out the card. Then, re-insert it firmly into the slot or try
another slot if you have another one free. Make sure to tighten the
screw to fix the card to the case, and put one there, if it's missing.
Here's a you tube video about how to install a sound card:
If
none of the above methods worked, pull out your sound card and test it
in another computer. You can also try re-installing Windows and lastly
try another sound card, if it still fails to work.Than at last go to near
computer shop.
Hope that helps, Regards, Pankaj
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
You can find the driver updates here:
http://abit.ws/page/en/motherboard/motherboard_detail.php@pMODEL_NAME=KV8-MAX3&fMTYPE=Socket%20754&pPRODINFO=BIOS
Hi Klex,
I was able to find the website address www.kdsusa.com through one of their products on Newegg, but the site appears to no longer exist. They also had a phone number listed (1-800-283-131) but that too doesn't seem to work. I have the feeling that they have either close their business or ended their operations in the U.S..
Sorry I didn't have better information for you.
