20 Most Recent Hoover UltraCare HC6 130M Front Load Washer Questions & Answers
2answers
My Hoover Ultracare 1300 washing machine has just
Yes. the pump may be blocked. look at the bottom of the washing machine front and you will see a flap undoo this and take out any bitts stuck in. Caution. Make sure the washing machine is un pluged and when you unscrew that plug. all of the water will come out of the machine. Best to do it outside. If that dose not work it means the pump has blown.
8/5/2011 8:22:59 PM • Hoover UltraCare... • Answered on Aug 05, 2011
Where can I get hold of a user manual for Hoover
Try searching through Google!
3/31/2010 5:37:02 AM • Hoover UltraCare... • Answered on Mar 31, 2010
Hoover ultracare 1300 large load stopping mid
Checkout your filter at the bottom of the machine, undo the bottom flap below the door, front. Plug off the wall mains socket. Be prepared for a lot of water so keep plastic bag, towels ready. Unscrew the plug you see to make water flow into bag; when all water has been disposed off, clean this filter & inside, refit carefully.
2/16/2010 7:14:13 AM • Hoover UltraCare... • Answered on Feb 16, 2010
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
3/12/2009 3:24:25 PM • Hoover UltraCare... • Answered on Mar 12, 2009
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
2/8/2008 9:11:18 PM • Hoover UltraCare... • Answered on Feb 08, 2008
Hoover washing machine shows lock symbol and won't start
How can I turn the red lock symbol off on my Hoover? Washing machine 300 light.
1/25/2024 4:59:19 PM • Hoover Washing... • Answered on Jan 25, 2024
2answers
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
12/7/2023 5:47:52 PM • Hoover Washing... • Answered on Dec 07, 2023
My Hoover WDYNS 654D-80 washing machine now displays E05 error. Please what is he possible fault and how can i fix it?
Hello, check youtube link or search for Hoover e05 error. I hope to be usefull. All the best !
9/9/2023 7:40:01 PM • Hoover Washing... • Answered on Sep 09, 2023
My Hoover H dish wont start when i touch the start buttons i have 3 flashing lights
When you encounter flashing lights on your Hoover H dishwasher and the appliance is not responding as expected, it indicates that there might be a problem with the dishwasher's operation. The specific meaning of the flashing lights can vary based on the dishwasher model and its error code system. However, here are some general troubleshooting steps you can take:
  1. Check the Manual: Refer to your dishwasher's user manual or guide. Look for a section that explains the meaning of the flashing lights and any corresponding error codes. The manual may provide guidance on what steps to take to resolve the issue.
  2. Power Reset: Turn off the dishwasher and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can sometimes reset the control board and resolve minor glitches.
  3. Check for Door Lock Issue: Some dishwashers have a safety feature that prevents them from starting if the door is not closed properly or the door latch is faulty. Make sure the door is securely closed and the latch is functioning correctly.
  4. Check Water Supply: Ensure that the water supply to the dishwasher is turned on and there are no kinks or blockages in the water inlet hose.
  5. Inspect Drainage: Check the dishwasher's drainage system for any clogs or obstructions. A blocked drain can prevent the dishwasher from starting.
  6. Cancel Any Previous Cycles: If there was a previous cycle that was interrupted or not completed, try canceling that cycle and then select a new cycle to see if the dishwasher starts.
  7. Child Lock: Some dishwashers have a child lock feature that can prevent the appliance from starting. Check if your dishwasher has this feature and make sure it's not activated.
  8. Error Codes: If your dishwasher has an error code display, note down the specific error code that corresponds to the flashing lights. Look up the error code in your manual or online to understand what the issue might be.
  9. Professional Service: If none of the above steps resolve the issue and your dishwasher is still not responding, it's advisable to contact Hoover customer support or a professional appliance technician for further assistance. They can diagnose and repair any more complex issues that might be affecting your dishwasher.
Remember to always prioritize safety when working with electrical appliances. If you're unsure about any step, it's best to seek professional help.
8/5/2023 4:39:07 PM • Hoover Washing... • Answered on Aug 05, 2023
2answers
My hoover dynamic washer is not showing an error code but all the lights are flashing and beeping all the time.
If your Hoover Dynamic washer is not displaying any specific error code but all the lights are flashing and it's beeping continuously, there might be an issue with the control panel or a more general system malfunction. Here are some steps you can take to troubleshoot the problem:
  1. Power Cycle the Washer: Turn off the washer and unplug it from the power outlet. Wait for a few minutes, then plug it back in and turn it on again. Sometimes, this simple reset can resolve minor electronic glitches.
  2. Check for Overloaded Washer: If the washer is overloaded with clothes, it can cause the control panel to act abnormally. Try running a smaller load and see if the flashing lights and beeping stop.
  3. Inspect the Water Supply: Ensure that the water supply to the washer is adequate and not restricted. Low water pressure or a clogged water inlet can cause unusual behavior in the washer.
  4. Check the Drainage: Make sure the drainage hose is not clogged or kinked. A blocked drainage system can lead to improper functioning of the washer.
  5. Examine the Door Lock: If the door lock is not engaging properly, the washer might not start or show unusual behavior. Check if the door is securely closed and the lock mechanism is functioning correctly.
  6. Check for Leaks: Look for any leaks around the washer. Water leakage can trigger safety features, leading to flashing lights and beeping.
  7. Inspect the Control Panel: Examine the control panel for any physical damage, moisture, or dirt accumulation. Clean the panel gently and make sure all buttons and knobs are functioning correctly.
  8. Software Glitch: If none of the above steps resolve the issue, it's possible that the washer's control board has encountered a software glitch. In this case, you may need to contact Hoover customer support or a professional appliance repair technician to diagnose and fix the problem.
7/23/2023 3:34:09 PM • Hoover Washing... • Answered on Jul 23, 2023
Hoover Washer Dryer WDYN-9646P AUS is stuck on the soak operation - unable to change operations
The drain hose or the pump might be clogged.I would call a repair person to take a look at it.
7/8/2023 6:33:13 AM • Hoover Washing... • Answered on Jul 08, 2023
Blinking no:8 on Hoover DXA 47/1 AUS Washing Machine
if voltage to display board when it goes out bad board if no voltage bad power board or control board
5/17/2023 7:41:23 AM • Hoover Washing... • Answered on May 17, 2023
How do i remove the program selector knob from a hoover washing machine DYN9164DPG
To remove the program selector knob from a Hoover washing machine DYN9164DPG, please follow these steps:
  1. Unplug the washing machine from the power source.
  2. Locate the small metal tab located underneath the program selector knob.
  3. Use a flathead screwdriver to gently pry up the metal tab.
  4. Pull the program selector knob off the machine.
The metal tab acts as a locking mechanism to keep the knob in place, so be sure to pull the knob straight off the machine once the tab has been released. If you encounter any resistance, double-check that the metal tab is fully released before attempting to pull the knob off again. Once removed, you should be able to access and replace the selector switch.
2/28/2023 6:16:49 AM • Hoover Washing... • Answered on Feb 28, 2023
My hoover washing machine stopped working but is displaying padlock symbol but the padlock isn't locked correctly and it's not opened as well
The padlock symbol on your Hoover washing machine indicates that the child lock feature is activated. This feature is designed to prevent children from accidentally starting the machine or changing the cycle during operation. If the padlock symbol is displayed but the padlock is not locked, it's possible that there's a malfunction with the child lock system. To resolve this issue, try pressing and holding the "Start/Pause" button for several seconds until the padlock symbol disappears. If this doesn't work, try unplugging the machine from the power source for a few minutes and then plugging it back in. This may reset the machine and allow you to deactivate the child lock. If neither of these solutions work, consult the user manual or contact Hoover customer service for further assistance.
2/24/2023 10:58:21 AM • Hoover Washing... • Answered on Feb 24, 2023
Brand new, Hoover washing maschine doesn't turn on.
Try this first... Unplug for 5 minutes, should set it back to factory defaults.
12/7/2022 11:03:16 PM • Hoover Washing... • Answered on Dec 07, 2022
2answers
Washing Machine won't spin
Hi, you can close the door and test the machine first. If it does not work properly, then you can schedule an appointment with geeksquad bestbuy to repair the washing machine or replace it for you. Thank you.
11/22/2022 4:55:26 PM • Hoover Washing... • Answered on Nov 22, 2022
Candy heat pump tumble dryer not collecting water and taking forever to dry!
Condenser dryers are simple in operation. They use a heater element to force hot air to heat the clothes and turn the water to steam. That steam is turned back into water by drawing cold air into the machine and over the heat exchanger unit and into the drum. The problems with them is that they are slow to dry. Your best bet is to call for service, and the problem is likely the sensor probe or one of the thermal cut out. https://www.4candy.co.uk/tumble-dryer/ro-h10a2tce-80-31101805/catalogue.pl?path=111515,111515&model_ref=14378839&page=2 ..
9/30/2022 2:50:58 PM • Hoover Washing... • Answered on Sep 30, 2022
Hoover UltraCare HC6 130M Front Load Washer Logo
Popular Tags
17 questions posted
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
hoover ab130 water empty from drum
  • Washing Machines
