20 Most Recent
U-Line 75BWC Questions & Answers
I have a uline 75bwc and the repair man said the
The compressor is the heart of the unit. As long as the unit is in good shape it would be cheaper to replace the compressor. This unit is a simple unit so all the parts hold up pretty good.
5/18/2009 4:33:08 PM •
U-Line 75BWC
Answered
on May 18, 2009
Thermostat
stat is immediately behind the temp setting knob and inside a housing. prize off the knob and the housing is normally held by a couple of screws. take the housing off and stat will be in view
9/24/2008 5:43:34 PM •
U-Line 75BWC
Answered
on Sep 24, 2008
Stat
always disconnect from mains when you do that sort of thing.
disconnect from mains, short the two wires together - just tape them together - and see if cooling starts
9/9/2008 8:35:20 AM •
U-Line 75BWC
Answered
on Sep 09, 2008
U-Line 75BWC
if 10 years old then probably has a phial type thermostat. this may have 2 or 3 wires to it plus earth. connect all the wires together (but not earth) and if it is a stat problem, the compressor will start
9/6/2008 2:49:41 PM •
U-Line 75BWC
Answered
on Sep 06, 2008
The alert notification is from a u-line refrigerator and beeps even when door fully closed
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
6/1/2018 4:50:59 AM •
U-Line...
Answered
on Jun 01, 2018
