20 Most Recent Mintek LCD TV Progressive Scan DVD Player Questions & Answers
It's tough trying to find OEM (manufacturer's) remotes. You could purchase a universal remote and program it to your set. Mintek doesn't have many codes and I believe 259 should do it. Good luck :)
Mintek LCD TV... | Answered on Oct 01, 2011
I've had the same problem. I called Toshiba support and all they could say was to unplug it. Since I already had done that, they were going to send a service person over for a couple hundred bucks (which they get a cut of) to take it apart. Haa
Mintek LCD TV... | Answered on Jan 05, 2011
in this type of situation, you have no choice than to disassemble the unit, in order to gain access to the stuck disc in the built-in DVD part.
Once you are able to disassemble the unit, you can manually remove the stuck disc.
You will be needing a screw driver that can fit into the unit, loose out the screws and take the unit apart. Be careful while doing this.
Good luck.
Mintek LCD TV... | Answered on Oct 20, 2010
Try Encompass Parts Distrubtion 1-800-638-3328
UED 1-800-648-6657
Look on E-Bay under Electronics/ List part number or model number.
Mintek LCD TV... | Answered on Mar 04, 2010
U tries some soap washing the DVD disk surface.See if the laser read after that.
Mintek LCD TV... | Answered on Feb 25, 2010
On most DVD/CD players (including ones build into PC's and TV's) there is a hole in the front of the tray into which something like an opened paper clip can be pushed into to activate an emergency tray release to enable the user to recover a trapped disc. If this is not the case then you will need to "go in" unless your device is still under warranty in which case you should contact Mintek customer support (look in you user manual for information).
Mintek LCD TV... | Answered on Dec 12, 2009
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Mintek LCD TV... | Answered on Nov 15, 2009
To fix this problem, the following assumes you have unplugged and taken the back off the TV, and removed the metal shield around the mainboard. Open the back carefully as there are a couple of ground straps that must be unscrewed before the back is completely freed. There are plenty of lethal voltages inside the TV, so do this all at your own risk.
I'm an electrical engineer and I just fixed a DTV-265-D that I got with the same problem. I'm not 100% sure what fixed it, but I located the problem and can hopefully inspire some other findings by others. All TV/DVD buttons, and remote control signals go into a small miicrocontroller (U75) on the bottom left corner of the mainboard. This button converts all buttons and remote signals into a decoded data signal with a 5V level (normally high).
Just above and to the right of U75 is a small 8-pin chip that appears to split and send the data signal to the DVD module and the TV microcontroller at two different voltages. Pin 1 of this chip is on the bottom right of U18 and the pins increment counterclockwise. The important signals I found were:
-Pin2: 5V Data input from U75 microcontroller.
-Pin3: 5V data signal sent out the red wire of the connector next to U18 going to the DVD player.
-Pin5: 3.3V data signal sent to the main TV microcontroller.
-The other pins may switch this signal back and forth somehow, but I have no way of telling without a schematic
I found on my unit that something was causing the signal not to get properly to the TV or DVD player. I resoldered U18 and things started working again. I'm not 100% sure this is the final fix, but U18 IS THE ULTIMATE CAUSE OF THE PROBLEM. Neither buttons nor remote signals are ever getting to the DVD module or the TV. Once I resoldered, both signals on pin 3 and 5 were clean and everything worked again. U18 may need to be removed and replaced with a simple voltage divider to get the proper voltages to the proper modules, but I haven't tried to go there yet.
A way to test if this is your problem is to remove the red wire from the harness next to U18 (the harness going to the DVD player). Somehow connect this wire to pin 2 of U18 (there's a convenient test point nearby), reconnect power, buttons, etc. and CAREFULLY test. Now, ALL the buttons for DVD control will work again but not the buttons on the TV side will work. You should be able to eject the DVDs and this may have unlocked this weird state. You would have to restore the red wire back to it's original position to have proper normal operation.
I used (and would highly recommend using) an oscilloscope to fix and debug this. There are plenty of lethal voltages inside the TV, so do this at your own risk and only if you at least kind of know what you're doing with electronics. So far it's been a week and everything is still working fine.
Mintek LCD TV... | Answered on Jul 27, 2009
I use a produce bag twist tie or a very thin pearing knife. After you push the eject button slide the twist tie in the bottom of the disc slot and the dvd should pop out.
Mintek LCD TV... | Answered on Jul 15, 2009
I use a produce bag tie. Stick it in the bottom of the dvd slot after pushing the eject button and the disc pops out for me.
there should be a small hole you can push a small paper clip or anything else small in, small round hole, will eject the tray.
Mintek LCD TV... | Answered on Jul 13, 2009
I am going to sandbag it. I can use that particular cd to workout with. I will just attach a dvd player separate since most postings can't use the dvd anyway after they get the cd out. Thanks for the help anyway! Susan
Mintek LCD TV... | Answered on May 28, 2009
If you have a optical out on your dvd player and optical in on the receiver that is the best connection for digital sound, the vcr section will have to be hooked up analog using rca cords
Mintek LCD TV... | Answered on May 27, 2009
It does not appear you will find them. The last time their web page was active was in August 2007. =>
http://web.archive.org/web/*/http://www.mintekdigital.com
They had a recall of portable batteries and a lawsuit on infringement. The parent company is Jiangsu Digital Technology Co., Ltd. ("Shinco Digital").
The website is down and the phone numbers don't seem to work. Last known address.
Mintek Digital Inc. Private Company, Headquarters Location
4915 E Hunter Ave., Anaheim, CA 92807, United States
(866)709-9500, (714)777-3090, (714)777-5933 fax, http://www.mintekdigital.com
Mintek LCD TV... | Answered on Apr 30, 2009
I purchased my Mintek from Costco and had the same problem. They are aware of the problems with Mintek and lack of support. If your set is from Costco or other stores try them for a solution or refund. It worked for me. I got a full refund. Most retailers have a copy of the reciept if not try anyway.
Good Luck
Mintek LCD TV... | Answered on Apr 06, 2009
clear its lense.if it is in warranty replace by the company
Mintek LCD TV... | Answered on Jan 20, 2009
The code is 0216. The problem is the universal control accepts the code, it still will not work.
Mintek LCD TV... | Answered on Dec 24, 2008
Mintek LCD TV Progressive Scan DVD Player Logo
Popular Tags
33 questions posted
Top Mintek Televison & Video Experts
Ekse
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mintek Televison & Video
Most Popular Question
mintek dtv 265 d dvd broke
  • Televison & Video
