20 Most Recent Sansui TVS2750 27" Questions & Answers
Dark screen
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
7/16/2017 1:32:26 PM • Sansui TVS2750... • Answered on Jul 16, 2017
SANSUI SCS21SDR
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. http://electronicshelponline.blogspot.com/
1/22/2014 1:41:27 PM • Sansui TVS2750... • Answered on Jan 22, 2014
Local channels wont come in I have all of the upper channel but no 3,8,30,gone?
sounds like one of the bands of channels in your set's tuner is now bad.
12/13/2012 9:22:49 PM • Sansui TVS2750... • Answered on Dec 13, 2012
What fuse to use
Use a 3.5 Amps 250V rated fuse.
7/26/2012 1:27:38 PM • Sansui TVS2750... • Answered on Jul 26, 2012
Hi there My Sansui TV screen
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
1/7/2011 10:07:38 AM • Sansui TVS2750... • Answered on Jan 07, 2011
Will not turn on and off
If totally dead check plug fuse, if you get a standby light ,and it wont come on by remote then , it could be power supply a problem, could be capacitors leaky in power supply. not a job for the novice,
pete
11/15/2010 10:49:34 PM • Sansui TVS2750... • Answered on Nov 15, 2010
TVS2740B, how do I switch from TV to Video Input manually?
going to have to get a universal remote with input button on it, or tv/vcr button, had same problem!!
1/4/2009 9:28:02 PM • Sansui TVS2750... • Answered on Jan 04, 2009
Sansui Mod. TVS2745, May 2002
I'm sorry. No.
10/23/2008 12:21:17 AM • Sansui TVS2750... • Answered on Oct 23, 2008
My jensen tv has no color when hooked up to playstation2 (modelts2750j)
same with my ps2
9/3/2008 10:43:03 PM • Sansui TVS2750... • Answered on Sep 03, 2008
2answers
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
8/24/2007 2:00:27 AM • Sansui TVS2750... • Answered on Aug 24, 2007
Sansui 27"
I think you're on the right track. It sounds like the problem is in the horizontal deflection circuit or pincushion circuit.Maybe a bad solder connection or a resistor burned loose from the circuit board. Stargazer
4/24/2007 5:49:31 AM • Sansui TVS2750... • Answered on Apr 24, 2007
I have a 19' sansui tv that is all in french. How do I get it to English without a remote?
You can't. All televisions need a remote to do anything in Settings. Also, you realize that it may be for the French home market and it only comes in French. Google make model remote replacement They are about $20 for a facsimile remote, an exact copy of the original. https://www.remotes.com/Articles.asp?ID=477 ..
10/6/2021 9:19:46 PM • Sansui Televison... • Answered on Oct 06, 2021
Need an instruction manual for the Sansui LPR 1002. What software is used with it?
I could not locate a manual for this product. It appears to have been sold in the past in South Africa at HIFI Corp. For Windows PC, Audacity if free. https://sourceforge.net/projects/audacity/ There are also software programs for sale, such as LPRecorder. For Apple Macs, Garage Band can record.
10/2/2021 7:24:49 AM • Sansui Televison... • Answered on Oct 02, 2021
2answers
How ddo I change my sansui tv from analog to digital without a remote
Without a remote control, you can't. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
9/30/2021 6:45:12 AM • Sansui Televison... • Answered on Sep 30, 2021
Sansui VRDVD4001A VCR rewinds the tape when you press play
This problem is caused by due to the tape bunching up underneath the flap. Try pressing and holding down on the small release button on the side of the VCR and then lift it up on the flap. Smooth out any build up of the tape by spinning the circular spindles on the tapes clockwise until the tape has become in a straight possession again.
8/23/2021 8:15:11 AM • Sansui Televison... • Answered on Aug 23, 2021
How to get the Sansui 32 inches smart TV Play protect certified
Contact DSTV customer support.
8/2/2021 9:13:17 PM • Sansui Televison... • Answered on Aug 02, 2021
Sansui TVS2750 27" Logo
17 questions posted
Top Sansui Televison & Video Experts
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
sansui tv screen
  • Televison & Video
