20 Most Recent Hoover HDV7FM Electric Dryer Questions & Answers
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Hoover HDV7FM... • Answered on Mar 19, 2015
Most likely, remove water collector, look under machine there is a part that meets water collector that needs to be removed and cleaned
Hoover HDV7FM... • Answered on Oct 20, 2013
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Limit switch or the element is most likely damaged.
Hoover HDV7FM... • Answered on Oct 28, 2010
The limit switch(es) or the element is most likely damaged.
here is the procedure:
1) There are 3 screws on the rear at the top that hold a plastic strip, remove the screws and the strip.
2) Slide out the top panel to the rear.
3) In each of the top front corners there is a screw, remove it and slide the top trim bars back and remove.
4) Tilt the machine backwards; remove 3 screws from the front underside.
5) Remove 2 screws from the top panel behind the control panel trim (each one about 2” inboard of the corner screws in step 3.)
6) Take note / photograph the mains switch connections, controller PCB connections and control knob connection. Remove the connectors and the control knob.
7) Slide the control panel to the right and remove.
8) Open the door.There are 2 screws by each hinge on the left.There are another 2 screws to the right.Remove 2 screws on the hinge side that have the same heads and level with the screws on the right.Remove the 2 screws on the right.
9) Pull off the front panel.
10) Remove the lint trap.
11) Remove the 2 screws that secure the lint trap housing to the front support frame. (Look up at the lint trap from the floor, they are under the front edge of the lint trap housing, one on each side.)
12) Support the drum (you can use a solid cardboard box that just fits between the drum and the machine floor.)
13) Remove the 4 M4 head screws (8mm box spanner) that hold the front support frame to the chassis.
14) Lift the front support frame up and pull the lower part forward to release it from the chassis.
thanks ,keep updated and accept the solution
Hoover HDV7FM... • Answered on Sep 10, 2009
It could be the temprature sensor located behind the front cover, it has 2 red wires and is an easy replacable and cheap part.It will need the top removing,front switch cover removing and then the screws for the front cover but not the screws securing the door as this will come off as one. Hope this helps
Hoover HDV7FM... • Answered on Mar 31, 2009
Try here: http://www.searspartsdirect.com
Hoover HDV7FM... • Answered on Jul 12, 2008
very difficult job. will seem like the new belt is to small. u will need plenty of patience and band aids. take the front off the machine leavin the drum supported only by the rere bearing. slide belt around drum and onto motor pulley keeping the spring loaded pulley on the inside of the belt. (ex hoover engineer)
Hoover HDV7FM... • Answered on Feb 10, 2008
kerry roffe Mar 21, 2021 Press the button on the door where it latches and it should start
Hoover Dryers • Answered on Mar 21, 2021
I would need to be there to see what you have going on, sorry,.
Hoover Dryers • Answered on Nov 27, 2020
Hoover HDV7FM Electric Dryer Logo
24 questions posted
Top Hoover Dryers Experts
Dan Webster
Dan Webster
Sheldon Dedek
Gerry Harvey
Gerry Harvey
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hoover Dryers
  • Hoover Dryers
Most Popular Question
hoover ohnv171x vented tumble dryer
  • Dryers
