20 Most Recent Hoover HDC6 Electric Dryer Questions & Answers
2answers
Hoover HDV6UK keeps tripping circuit breaker
There are only 2 things that it could be both are heat related: THe thermostat and thermal limiter OR the heating element. We can not rule out the motor though. Then you can get into the control boards. Maybe it is time.
7/12/2017 4:36:48 AM • Hoover HDC6... • Answered on Jul 12, 2017
2answers
Hoover tumble dryer vhc392T drum not turning.
check the belt to see if it is broken. check the drive motor to see if it is working.
7/24/2014 10:35:53 AM • Hoover HDC6... • Answered on Jul 24, 2014
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
6/15/2014 1:55:25 PM • Hoover HDC6... • Answered on Jun 15, 2014
Drum will not rotate
change your capasitor
4/10/2014 12:05:54 PM • Hoover HDC6... • Answered on Apr 10, 2014
3answers
Re-Hoover nextra8 hnc380 Tumble dryer
Had this problem with mine. Its the belt tensioner pulleys that have seized and cause the noise.I got 2 net tensioners and fitted them myself.The parts come to about £15 but its a total strip down to replace the parts. been working fine now for about a year
11/15/2013 2:25:27 AM • Hoover HDC6... • Answered on Nov 15, 2013
Hoover hd condensing dreyer cuts out and water
Make sure that drain is free, that the dryer has adequate ventilation and that the lint has been cleaned from inside. Those are all reason.
9/22/2011 10:48:08 AM • Hoover HDC6... • Answered on Sep 22, 2011
Hoover dryer not turning over
kind of vague but it may be your belt is off, of course we can think the worst and say the motor is shot. Bottom line we need to open up the machine and do a little troubleshooting. Here is a website that can get you into the machine, if it is not the belt, post again and if I'm on here I will try to help Tim:
http://www.diyprojectsonline.com/projects/interior/fix_dryer_belt.php
3/19/2011 1:44:22 PM • Hoover HDC6... • Answered on Mar 19, 2011
Stops when start button released
http://www.applianceaid.com/evenheat.html
2/27/2011 2:37:44 PM • Hoover HDC6... • Answered on Feb 27, 2011
I have a Hoover tumble
Try hitting the reset button on the back side of the dryer.
Yank out your condenser and give it a good clean.
A nice video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/2/2010 8:19:05 PM • Hoover HDC6... • Answered on Dec 02, 2010
The heater is not working
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
10/9/2010 9:31:40 AM • Hoover HDC6... • Answered on Oct 09, 2010
My hoover nextra8 condenser tumble dryer turns on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/12/2010 10:25:51 PM • Hoover HDC6... • Answered on Sep 12, 2010
Hoover Dryer Mod. HNC 271X-88 In
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
7/2/2010 9:37:30 AM • Hoover HDC6... • Answered on Jul 02, 2010
When you press the on button nothing happens
There is a switch on the motor that replace the push to start in the circuit once it gets up to speed. Either it is not reaching speed or the switch has failed.
Eric
6/13/2010 7:21:17 PM • Hoover HDC6... • Answered on Jun 13, 2010
HD6 dryer will not stay on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
5/20/2010 11:26:00 AM • Hoover HDC6... • Answered on May 20, 2010
Hoover HDC6 Electric Dryer Logo
Popular Tags
67 questions posted
Top Hoover Dryers Experts
Tim Whalen
Marvin
Marvin
Paul Carew
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hoover Dryers
  • Hoover Dryers
Most Popular Question
hoover tumble dryer vhc392t drum not
  • Dryers
