20 Most Recent
Samsung Notebook Np-n145 10.1" Laptop Motherboard Ba92-06885a Tested Questions & Answers
Samsung n145 will not power up
Related to a Samsung Np-n145 Notebook PC:Plug the laptop into power for 24 hours. See if the Battery charges up. Next test, or have tested, the AC adapter (Charger) See if it is putting out 19 Volts -> DC. Know someone with a multimeter? I can guide you in testing. AC adapter is good? Things go downhill rapidly here. The next problem could be a DC Power Jack.The DC Power jack is the jack on the laptop, that you plug the AC adapter into,1) The DC Power jack may be broken2) The solder joints holding it to the motherboard may be cracked. Poor connection to motherboard.The DC Power jack can be replaced, or it's solder joints re-soldered.DC Power jack proves to be okay?Power MOSFET's have gone bad. The next link, is an article that deals with bad Power MOSFET's in an HP laptop. Used for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.htmlLet's hope it's a bad AC adapterRegards,joecoolvette
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
Getting WGN - TV on Samsung television?
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Use Alexa with your Samsung TV or smart monitor
Samsung
https://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
How to connect your Samsung smart TV to Alexa
Tom's Guide
https://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
8/31/2023 5:09:22 PM •
Samsung...
Answered
on Aug 31, 2023
Samsung SGH-J700. I can't open .jar files from MicroSD on it.
It is a JDK Java X Runtime file
However, if you are still not able to run the file, here's what you can do:
- Right-click on the JAR file.
- Go to "Open With Other Applications".
- Select Show other applications.
- Select Open With OpenJDK Java X Runtime.
- If you don't find the Java option, install JRE.
Jun 25, 2023
How To Run & Open A JAR File (.JAR File Opener)
Software Testing Help
https://www.softwaretestinghelp.com > how-to-open-a-ja...
How to Open JAR Files on Windows 10 and 11
How-To Geek
https://www.howtogeek.com > Windows
Jul 5, 2022 - To run a JAR file on Windows 10 or Windows 11, right-click it, then select Open With > Java Platform SE Binary. Alternatively, you can view ...
What Is a JAR File and How... ·
Step 2: Download and Install...
How to open a JAR file
TheServerSide
https://www.theserverside.com > blog > How-to-open-...
Jun 7, 2022 - Change the extension of the JAR file from .jar to .zip · Right-click on the JAR file and select Extract All · View the contents of the open JAR ...
How to Open a Jar File
Computer Hope
https://www.computerhope.com > ... > Software Help
May 1, 2023 - Manually choose program to run jar file · Right-click the file and select Open With. · In the Open With window, click the Browse button to open ...
8/12/2023 5:59:26 PM •
Samsung...
Answered
on Aug 12, 2023
