20 Most Recent
GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset Questions & Answers
My M1 from Sayno and my jabra b260s
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Pairing with my Sony Ericsson w810i's MP3 player
hi stefan,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
GN 9350 randomly switches out of telephone mode into computer mode during a call.
If you haven't already tried this, disconnect the base unit from the computer and then see if the problem continues. If it does, there is likely a fault in the electronic switching in the base unit. If the problem doesn't continue, then it could be an intermittent switch on the base unit. You could try pressing and releasing the computer switch on the base unit multiple times. Maybe even lightly pry it up with your fingernail to make sure it's not stuck down. From my understanding any phone connection will override computer audio, so while on a phone call even if you computer beeps, it should not switch to computer audio. Hopefully this will narrow down the issue.
Password doesn t work
Many reasons that could be happening. Could need re pairingwith docking station, might need to play with the compatibility dial.
