20 Most Recent Eureka 4700A Maxima Bagless Upright Vacuum Questions & Answers
2answers
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
7/10/2021 9:12:37 PM • Eureka 4700A... • Answered on Jul 10, 2021
4answers
How to change belt on Eureka maxima 4700a
hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out, [email protected]
9/17/2017 5:11:42 PM • Eureka 4700A... • Answered on Sep 17, 2017
Vacuum shuts off after 2-5 minutes and won't turn back on until 30 minutes. No clog ups, canister is empty, filter is clean, suction hose is cleared and brushes are clean. What is the problem?
problem with over heating motor ( possible short in windings ) have it checked out in a vacuum repair shop
5/11/2016 5:48:09 AM • Eureka 4700A... • Answered on May 11, 2016
2answers
How do I change the belt on Eureka 4704 and where
Hi, you can get belts (quality for great price) from amazon, here: Amazon com Eureka 4700A belt. Wish you best of luck. Ryan
1/7/2015 1:08:02 AM • Eureka 4700A... • Answered on Jan 07, 2015
4704 manual
2 screws on lid lift off lid put handle down
6/21/2014 1:42:31 PM • Eureka 4700A... • Answered on Jun 21, 2014
0answers
0answers
Roller not moving
That is called the beater bar. You need a new belt. Remove any hair etc from the bearing while you have it apart
11/30/2013 4:26:11 AM • Eureka 4700A... • Answered on Nov 30, 2013
I have a Eureka Maxima bag-less. I just changed
What is the height setting?
9/27/2013 3:06:45 AM • Eureka 4700A... • Answered on Sep 27, 2013
Reset switch
There is no reset button it as a Thermal Cut OffThis vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenlyshuts off, turn the switch off and unplug the cleaner.Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fixthem and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in andturn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistancethis link below is the manual http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
9/5/2013 1:11:13 PM • Eureka 4700A... • Answered on Sep 05, 2013
When i turn on vacuum it spreads the dirt i am trying to pick up all over the floor, then a need to revacuum the floor. Pls help.
sounds like you need to change bag and clean out hose and dirt channel underneatch behind brushroll.
2/19/2013 11:24:29 PM • Eureka 4700A... • Answered on Feb 19, 2013
Eureka4701bagless upright vacuum
dont know what the problem is but this link is for the manualhttp://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
10/29/2012 9:08:35 AM • Eureka 4700A... • Answered on Oct 29, 2012
Eureka 4700A Maxima Bagless Upright Vacuum Logo
115 questions posted
Top Eureka Vacuums Experts
David Shaub
Steve
Mike
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Eureka Vacuums
  • Eureka Vacuums
Most Popular Question
vacuum shuts off after 2 5 minutes turn
  • Vacuums
