20 Most Recent Canon ImageRunner 4570 | IR4570 | Questions & Answers
Indikator paper has jammed tidAK hilang
hi. is easier to us if you ask in English so we can help you out. you can check the flag sensors in the vertical path of paper .
1/14/2019 1:58:05 AM • Canon... • Answered on Jan 14, 2019
2answers
How to fix error 110 for cannon ir4570
the scanner motor does not work
3/27/2018 2:50:52 AM • Canon... • Answered on Mar 27, 2018
2answers
CANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
2/18/2018 1:34:09 AM • Canon... • Answered on Feb 18, 2018
What means this code E000225-0001 ?
The light intensity of CIS is faulty.Disconnect and than connect flexible cable,if necessary replace it,or replace reader controllerPCB
8/28/2017 3:49:41 AM • Canon... • Answered on Aug 28, 2017
When turn on it display the error code E000110-0001
have a read through the user manual ..if not there you need to call a service tech to come and fix it http://www.manualslib.com/manual/579340/Canon-Ir4570.html 26183493-wiv2epenzjiy1tbpzyhd3fmz-1-0.jpg
5/3/2016 9:06:10 AM • Canon... • Answered on May 03, 2016
Error code 0001
try to reset the eror first * 28* .check thermistor check fuser heating element
1/28/2016 3:33:39 PM • Canon... • Answered on Jan 28, 2016
2answers
Why error code E000000-0001
it is the encode on the fixing unit / fuse unit change the fixing film and then reset the error code by entering service mode then clear it
1/28/2016 3:32:03 PM • Canon... • Answered on Jan 28, 2016
3answers
Canon ir 4570 paper jaming in heater section what can i do
check your outlet delivery guide or whether your fuser film rotation
1/28/2016 3:29:24 PM • Canon... • Answered on Jan 28, 2016
Error code eoooo110-00001
check the laser unit or polygon motor, and the IP main board
1/28/2016 3:26:40 PM • Canon... • Answered on Jan 28, 2016
4answers
My Canon ImageRunner have this error code E000007-0000, what does it mean?
the rotation of the fixing film is faulty,you have to feplace it,or replace the main thermistor,if fix. film is okay.but first, reset it in service modeCOPIER<FUNCTION<CLEAR <ERR
1/28/2016 3:23:16 PM • Canon... • Answered on Jan 28, 2016
Copy Machine is running ready but can't print and copy.
The paper tray is not placed properly leading to erroneous sensing place the paper trays properly
9/28/2015 12:49:37 PM • Canon... • Answered on Sep 28, 2015
Paper jam?
my dear you change paper feed roler
8/12/2015 5:34:28 PM • Canon... • Answered on Aug 12, 2015
Black line half page inconsistently black lines appear halfway the pages. A page or two may pass without the lines
The drum has been scratched by a paper jam. Needs replacing to eliminate those marks.
8/9/2015 8:26:16 AM • Canon... • Answered on Aug 09, 2015
How to fix id card fuction
first entered in SPECIALFETURES then IMAGE COMBINATION then (Machine Ask Original Paper Size) Select A5R (if the LTR Size Show tuch the AB botton) Select 2 on one then select A4 paper tray Then Screen Show Special features DO NOT TOUCH RESET or Any botton touch MODE MEMORY select M1 touch STORE then done then OK Press the Additional Function Bottoan touch Copy Setting touch Standred key 1 setting (in this Window show many botton) choose modememory Select M1 Select OK afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
2/25/2015 11:30:37 AM • Canon... • Answered on Feb 25, 2015
Error code E000007-0000
Dear 1) Turn off and then on the main power switch. Is the problem corrected? YES: Check the operation once again; if normal, end the work. Connectors, DC controller PCB 2) Is the connection of the connector (J1015) on the main controller PCB and the connector (J122) on the DC controller PCB normal? Further, is the cable between these connectors normal? NO: Correct the connectors/cable. YES: Replace the DC controller PCB. Thanks.
2/7/2015 3:42:33 PM • Canon... • Answered on Feb 07, 2015
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
1/30/2015 9:38:52 AM • Canon... • Answered on Jan 30, 2015
How do I resolve the code e00010-001
Hi I found the following description for your error Description:- The rotation of the main motor is faulty. Detection is executed every 100 msec after the start of motor rotation; however, the drive detection signal is absent for 2 sec. Remedy:- Replace the main motor. Replace the DC controller PCB. This was here: Error Codes Canon iR4570 Code E010 0001 On this webpage where you can change the code you are receiving to a different one if required (or view them all) by using the drop down menus along the top of the page. You can also change the make & model using the drop down menus if you wish. You can also get a Service Manual from this page using the link. Hope this is helpful, if so would you please register that with Fixya Cheers
1/1/2015 10:04:07 PM • Canon... • Answered on Jan 01, 2015
Canon ImageRunner 4570 | IR4570 | Logo
67 questions posted
old marine
old marine
Marvin
Marvin
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error code e000000 0001
  • Office Equipment & Supplies
