20 Most Recent
M&S Systems MCD-6 6-Disc CD Changer Questions & Answers
M&S Systems MCD-6 6 Disc CD Changer display of "err 01" message
I do not know these units but I have worked on multiplay and many devices, the main reasons I found is either lubrication and or drive belts.
Over time belts stretch from decay as they age also silicon based grease I have found becomes divided between a liquid and paste with the liquid part making a puddle on a units lower area.
This causes things not to operat within a suitable time due to friction or lack of power from those belts which result in error numbers.
A good service is the only answer with a good service engineer who I am sure will enjoy cleaning out the residue slime, clean parts and relubricate. Sarcastic of me maybe but it was to make you aware that it may be costly due to time involved.
Hope this helps.....
A cd is wedged in unit. can not remove cd changer
First press and hold Track-Up and Mode buttons at same time on unit for three seconds to reset disc player, then check if cd get release.
In some cases, performing a reset on the MCD6 may resolve your problem. First try resetting the MCD6 player by pressing the TRACK UP and POWER buttons at the same time. If that does not work, remove the plastic front cover by pulling straight out and press the RESET button below the keypad. If your MCD6 player still does not operate, please take off cover from cd player and try to manually release wedged cd in unit.
If loading gears worn out then nothing will help to fix the unit, please contact local repair shop or M&S Systems at (214).358-3 196
Hope these info will help you.
Let me know if you have any question.
Thanks.
My cd player was stolen from unit
If the serviceman took it in good faith to repair and it was never returned I would contact him and demand it back, or the authorities will be involved.
No display on MCD6 and
no power no action. check power source or call your place ware u brout it. if no help on get n it up n running u mite have 2 find a way 2 reboot it. or your unit is off system check.
