20 Most Recent
Focal -America FAA33A Car Speaker Questions & Answers
Problem with focal k2 power and focal fiberglass speakers in car
It could be the setup of the speakers, but I would install a crossover equalizer for your situations. A crossover equalizer is supposed to automatically filter the necessary frequencies to the correct speakers. I have used no name and brand name XverEQs and they both worked the same for me. Along with this response I am assuming you also have Mids and Highs to go along with the woofers.
How can i fix a focal sub that does not get
Sorry I do not believe that sub to be rebuildable. You can try running the sub with only 1 voice-coil but either way I think it is time for another sub unless it is a de-soldered tinsel lead (where you connect your wires to the sub).
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
