20 Most Recent
Harman Kardon HARMAN/KARDON SOUNDSTICKSII SoundSticks II Satellite Speakers & Subwoofer System System Questions & Answers
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
Why doesn't subwoofer work?
Your nose and eyes should lead you to the faulty part for this, once you get inside the subwoofer. Anything that burns up producing the smell will possibly leave a visual trace. But your nose will lead to the part that smells. Replace it and see what happens!
My MacBook's audio still on even when harman
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
My wife dropped one of my harman kardon sound
Find some adhesive such as Liquid Nails or Gorilla Epoxy and put a small amount on the speaker that has become dislodged. Make sure that the area where you put the adhesive will come in contact with the rest of the speaker tower.
Hi, I am looking for a new power supply/cable for
Well, from the picture it's a simple 120vac to 15vdc 2000mA device. Model Number 661520003CT
http://cfusion.com/parts/661520003ct/
Too bad they use a proprietary connector or you could just go to Radio Shack and snag one for a few bucks. At around $100 or more apiece the OEM supplers are gouging you.
I can'tthink of any reason it would have 3 unique conductors. It's DIRECT CURRENT - a Positive and a Ground.
The price all revolves arount that connector. I'd go to Radio Shack and buy an off-the-shelf AC supply then transplant the tip from the old one.
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
Harman kardon avr 146 no front led display. but clicks on from orange light to blue. is there a fuse for display screen ? fuse at AC in is OK.
Hello, there is no fuse for the screen, there is a power supply circuit that makes it work and that if it is wrong the screen does not work
The rest of the team works well? Can you hear something?
if not, you do not have a display problem, you have a bigger problem
If you have knowledge to review it, I will attach the service manual, but go to a specialized technical service
Hola, no hay fusible para la pantalla, hay un circuito de fuente de alimentaci?n que lo hace funcionar y que si esta mal la pantalla no funciona
El resto del equipo funciona bien?, puedes escuchar algo?
si no, no tienes un problema de display, tienes un problema mayor
si tienes conocimientos como para revisarlo, te adjunto el service manual, sino dir?gete a un servicio t?cnico especializado
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Harman-Kardon-AVR-146-Service-Manual.pdf
