20 Most Recent Olevia MN-27LCDTV-SN 27 in. Television Questions & Answers
change your power suply
Olevia... • Answered on Apr 21, 2009
This smudge do the colors look ok, or are they starting to separate? If so it may be a purity problem, might try to degauss the screen, some AC electric drills can do this.
Olevia... • Answered on Nov 10, 2007
In the owners manual it will explain how to get to the language menu, then shifr through it till you see english and click on it. If that does not help, go to the store where you bought it.
Olevia... • Answered on Oct 03, 2007
sadly not having that make locally I can not guess at what input choices you have here it might be free to air or just AIR
Olevia Televison... • Answered on May 03, 2021
No, the technology is different, and the connections aren't right.
Olevia Televison... • Answered on Apr 26, 2021
Nope, all sets NEED a remote control. Only basic functions from the set. Just buy a new remote SPECIFICALLY for that set
Olevia TV, Video & Home Audio Remote Controls for sale ' eBay
www.ebay.ca > Olevia-TV-Video-Home-Audio-Remote...
Results 1 - 35 of 35 - GENUINE OLEVIA ?LEVIA RC-LTU UNIVERSAL REMOTE 537-B11 537-B12 537H 542-B11. C $43.40. Free shipping. or Best Offer ...
Customer reviews: Universal Remote Control Fit ... - Amazon.com
www.amazon.com > product-reviews
Find helpful customer reviews and review ratings for Universal Remote Control Fit for Olevia RC-LTU 2500005701 537-B11 537-B12 537H 542-B11 542I 742I ...
olevia tv remote control - Amazon.com
www.amazon.com > olevia-tv-remote-control > k=olevi...
Results 1 - 16 of 118 - New RC-LTL Replacement Remote Control fit for Olevia 5 Series LCD HDTV 526 527 532 537 542 527S11 527-S11 527-S12 527V 532B1 ... ..
Olevia Televison... • Answered on Feb 15, 2021
Olevia-232V-Manual.pdf
static.highspeedbackbone.net > pdf > Olevia-232V-Man...
PDF Connect a 75-ohm coaxial cable (or choice of Antenna Cable) from your cable or antenna to the TV's. VHF/UHF jack (RF Terminal). For 226 and 232 Models. Rear ...
Olevia Televison... • Answered on Feb 09, 2021
Could be something is cooking inside - literally. Components such as resistors, capacitors, etc. do not have an infinite life and some in a circuit tend to be more stressed than others and so begin to wear out before others; mostly their values change rather than failing - life would be easier if things just failed... The trouble is, when component values change it can change the semiconductor bias of several stages with the probable result one or more components including semiconductors begin to consume more current which results in heat. If more heat is produced than a device can dissipate the temperature will increase until it can't function properly. When the screen rolls it is because the frame oscillator is losing synchronisation with the signal. Whether this is directly or indirectly connected to the flickering it is impossible to say. There could be a chicken and egg situation...
Olevia Televison... • Answered on Jan 21, 2021
The other co-ax probably used to connect with a set top box - cable maybe or satellite.
Olevia Televison... • Answered on Nov 11, 2020
I am guessing but there is little difference between a normal antenna and one supposedly intended for HD reception. Successful tv performance when HD channels are selected from the line up of available channels is dependent on receiving a strong high quality signal and if you are located in the right place in relation to the transmitter, something like a wire coat hanger will be enough but the greater the distance and/or the more difficult the local geography the better designed and higher performance antenna will be required. Antenna manufacturers aren't embarrassed about making misleading marketing claims. To the best of my knowledge there is no physical difference between an ordinary tv antenna and a so-called HD antenna, the latter would be better designed, higher quality, higher performing and more expensive. Choosing the right antenna for your immediate area is difficult and it is best to take the guesswork out by asking a reputable local antenna supplier and erector. The best quality coaxial cable will also be required. My tv doesn't have any means to select a type of aerial - a HD picture is displayed when a HD channel is selected. If your tv has such a selector it will undoubtedly be found in the menus...
Olevia Televison... • Answered on Sep 19, 2020
http://persepolis.wisc.edu/olevia_532_b12_user_manual.pdf
Olevia Televison... • Answered on Apr 19, 2020
if the cap is domed, the top is bursting upward, read the value on the side, might be something like 1000uF, 50V ,buy a part online, try to get one rated at 105 C, then you have to remove the board and solder the new part in. or write down the part number of the board, and model number, to buy the entire board online
Olevia Televison... • Answered on Nov 14, 2019
Olevia MN-27LCDTV-SN 27 in. Television Logo
Popular Tags
12 questions posted
Top Olevia Televison & Video Experts
josepovedaca
Level 1 Expert
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
picture problem
  • Televison & Video
