20 Most Recent Olevia LT32HVE 32 in. LCD Television Questions & Answers
Call your service provider and have them re-boot your digital reception system.
Olevia LT32HVE... | Answered on Oct 16, 2017
It sounds that the back-light ivnerter has the fault. Contact any service technician before confirmation.
Olevia LT32HVE... | Answered on Dec 02, 2013
YOU TRAY TO FIND SERVICE MOD ON THE NET I THINK IT IS MENU 4725 AS NUMBER AND TORN OF PARENTAL LOOK THE 9999 IS NAT A RIGHT NO
Olevia LT32HVE... | Answered on Oct 31, 2013
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Olevia LT32HVE... | Answered on Oct 21, 2013
To reset the TV to its factory settings, you have to enter its service mode option. Reset option can be selected in this mode. If you wish to get more details about how to enter, adjust and exit the service mode, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'.
Olevia LT32HVE... | Answered on Aug 22, 2013
no reception is either the tuner or something set wrong in the set, av jacks on back still work?
Olevia LT32HVE... | Answered on Sep 03, 2012
tried to hooked up in other component input, just to ensure if compatible or supported in dvi.
Olevia LT32HVE... | Answered on Sep 02, 2012
have you checked under the misc menu and be sure parental controls are all off and no channels or rating are being blocked?
Olevia LT32HVE... | Answered on Aug 07, 2012
Please go through the operation manual, that is the best.
Olevia LT32HVE... | Answered on Aug 01, 2012
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
Olevia LT32HVE... | Answered on May 23, 2012
make sure connected via the correct input and if using a box signal is outputted correctly.
Olevia LT32HVE... | Answered on May 14, 2012
Hello
Enter into the Menu options, surf through, and come to picture adjustment window. Here you can set all adjustments to picture.
Olevia LT32HVE... | Answered on Mar 01, 2012
Hi logo and no signal can be a lot of things. You siganl board could be bad your backlight inverters caould be back. or your backlight itself can be bad. The first tihing I would check would be the backlight inverter.
You can get parts for this TV at www.interliquidparts.com
Olevia LT32HVE... | Answered on Feb 29, 2012
Please try to play any DVD movies to determine if the problem is on the TV or on the cable/aerial connection and reception..
If you play DVD and works fine?
The TV is good but the problem is on the aerial antenna if you are using analog..and if you are using digital cable please double check the connection and cable box..or try to contact your cable provider..
Olevia LT32HVE... | Answered on Dec 19, 2011
Olevia LT32HVE 32 in. LCD Television Logo
124 questions posted
Top Olevia Televison & Video Experts
CoppellTVRepair.com
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
humming noise from tv when first turned
  • Televison & Video
