20 Most Recent Milwaukee Tool Master Heater 70,000 BTU Kerosene Salamander / Torpedo Heater B70ET Questions & Answers
Comes on but cuts out
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
2/1/2024 9:02:48 PM • Milwaukee Tool... • Answered on Feb 01, 2024
Protemp heater is not running right and blowing black smoke before it kicks on
Sounds like you need a new nozzle and filter. Clean the pump strainer too.
12/17/2013 1:51:58 PM • Milwaukee Tool... • Answered on Dec 17, 2013
Fan runs for a minute
Here is a tip about troubleshooting Torpedo Heaters
heatman101
11/11/2010 3:30:07 AM • Milwaukee Tool... • Answered on Nov 11, 2010
I have a kerosene torpedo
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
10/31/2010 5:44:07 PM • Milwaukee Tool... • Answered on Oct 31, 2010
No fuel to my torpedo heater
heatman101
10/31/2010 5:41:58 PM • Milwaukee Tool... • Answered on Oct 31, 2010
Can a Kerosene leak outside be dangerous?
It could be a fire hazard and if enough leaks into the ground the EPA could get involved. Probably a lot cheaper to fix it.
3/16/2010 8:53:22 PM • Milwaukee Tool... • Answered on Mar 16, 2010
Not much heat output, and fumey model BY100CEA
Check the nozzle, if it is dirty you can get a stream instead of a spray and the fuel won't burn completely.dI would also make sure the blower wheel or fan is supplying enough air for compustion.
1/26/2010 8:34:42 PM • Milwaukee Tool... • Answered on Jan 26, 2010
I am having trouble getting my 50,000 btu torpedo heater started.
your nozzle is plugged.to clean the nozzle you take the cover off,slide the motor out of it's slots and push it to the rear of the unit,remove the air line and fuel line,remove the three 3 screws holding the nozzle assy. on.once you have the nozzle assy. out you will see a brass nozzle on the inside,put nozzle assy. in vise to hole it.take 5/8" socket and remove the nozzle from holder.take the nozzle holder out of vise and put brass nozzle in vise.do not put a lot of pressure on it or you'll bend it.by the way pointy end down so you can take the nozzle apart.once you have the nozzle in vise,take a pair of plyers and carefully remove the inside of nozzle,it doesn't take a lot of pressure to turn the inside.just loosen it don't take it apart yet....remove it from vise and turn it uside down so pointy end is now facing up.rotate it over the work bench so you don't drop the piece that's inside.very tiny piece..... that the nozzle,it rotates inside to make the spray pattern.look through it and see if you can see light throught it.take an air nozzle and carefully blow through it....both ways.look again and see if it's clear.once it is replace everything in reverse order.do not put much pressure on the inside piece of nozzle when you tighten back in with the plyers.hope this helps........let me know
4/2/2009 4:03:15 PM • Milwaukee Tool... • Answered on Apr 02, 2009
TORPEDO KEROSENE HEATER DOES NOT STAY LIT. I
The fact that it lights up at all should tell you its not the ignitor. Does the unit have a thermostat? What temp do you have it set at? Does the unit blow into a corner or some way that the therostat is being activated to cut out by the hot air getting back to it before the rest of your space gets warm?There are so many questions.Does the flame go out first,or does the power to fan kik out with the flame? This could be related to a faulty or out of position tip over cut out,witch is for safety.I'm going to help you by teaching you to help yourself. Troubleshooting is a series of tests. Most every machine is nothing but a bunch of valves,and switches.First find out if its running out of fuel,,or cutting operation all together.If its running out of fuel to the firing rack you be able to see and hear it,,,NOTICE that it looks and sounds like its petering out.If its cutting fuel,fan,and power instanly then its most likely the thermostat shutting it off ,,or the tipover cutout. It could be a multitude of things.The best way to find out is to figure out how the machine works,,,understand the componits that make it up and what they do,,then single them out one at a time and test them to eliminate them from the list of possible problems. UNDERSTAND? If the ignitor clicks and the rack lights up,,,its not the ignitor,after all the ignitor IS igniting. Find out more about whats up with it and repost,,good luck bud.
12/25/2009 11:39:49 PM • Milwaukee Tool... • Answered on Dec 25, 2009
WE HAVE A FEDDERS AZ7A09W2A Through the Wall Room Air Conditioner. IT WILL NOT TURN OFF. PULLING THE POWER CORD IS THE ONLY WAY. DOES ANYONE KNOW THE CAUSE AND OR REPLACEMENT PART?
Question edited for clarity, full 'make model (what it is)'. Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks! Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Repair Clinic has some good ideas, but your model is discontinued
Fedders Air conditioner won't turn off
Repair Clinic https://www.repairclinic.com > RepairHelp > Fedders-Ai... Here are the most common reasons your Fedders AC compressor won't turn off - and the parts & instructions to fix the problem yourself.
Why Your Air Conditioner Isn't Shutting Off, and How to Fix It
Williams Comfort Air https://williamscomfortair.com > ac-wont-shut-off When your air conditioner won't shut off, it's natural to worry about wasting electrical power as temperatures become too cool for comfort. ..
4/24/2024 1:44:56 AM • Heating &... • Answered 14 hours ago
2answers
I have a Bonair evap aircon model VSL75 with the comfort controller and I want to reduce the water dumping cycle down. I have tried the manual but that sequence didn't work.
Here are the steps you might want to follow: Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping. Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off. If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
4/21/2024 11:19:53 PM • Heating &... • Answered 2 days ago
What is E3 in frego split ac
Frego split ac error code h3 what is problem
4/16/2024 4:25:39 AM • Heating &... • Answered on Apr 16, 2024
2answers
What does E2 code mean on electric infrared heater
Model 2320cpb. E2 code
4/13/2024 11:00:34 AM • Heating &... • Answered on Apr 13, 2024
HP error code in bluestar split ac
Blue star inverter Ac HP error shown on display
4/10/2024 7:14:47 AM • Heating &... • Answered on Apr 10, 2024
2answers
Hello How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM • Heating &... • Answered on Apr 09, 2024
My azure split ac see the error code df sir pls give me solution for df error
Azure 1.5 ton splits ac old model e2 error
4/9/2024 12:44:23 AM • Heating &... • Answered on Apr 09, 2024
My Goldair gas heater ignites but the centre burner does not glow or come on. What could be the problem?
Blocked jets clogged with dust or dirt, blocked injector need a clean / service
4/8/2024 8:36:41 PM • Heating &... • Answered on Apr 08, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps: Unplug the heater from the power source. Locate the Manual Reset Button on the heater. It's usually a small button or switch. Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button. After resetting, plug the heater back in and check if it functions properly. Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM • Heating &... • Answered on Apr 07, 2024
Heating & Cooling Logo
Popular Tags
15 questions posted
Top Milwaukee Tool Heating & Cooling Experts
Paul Carew
john h
Are you a Milwaukee Tool Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Milwaukee Tool Heating & Cooling
Most Popular Question
fan runs minute
  • Heating & Cooling
