20 Most Recent
Oreck Walnut Air Purifier Air8Wa Air Purifier Questions & Answers
Should I run unit with
It seems that you would be changing lots of air volume with windows open and the attic fan on. I suggest turning off the unit unless the room is closed, so it can recirculate and clean THAT air.
Can't find ORECK filter #AT2PK, been waiting for
They discontinued it. Just go to any aquarium and buy a carbon filter pad and cut it to size. They sell big sizes for under $10 and just stick it in your Oreck Air 5 air purifier. Works just as well and cheaper!!
9/6/2017 10:10:24 PM •
Oreck Air...
Answered
on Sep 06, 2017
Need a wiring diagram for Oreck XL air purifier Air8SD
I would look at the board using a high powered magnifying glass to see if there was any signs of broken stubs of wires sticking out of any solder joints. Also look for solder joints that have no other possible routes, (dead ends) that do not have any other connections running from them. Like a resistor that has a copper path on one end and nothing running from the other end. Or it could be a ground wire if no other spot is found.
11/6/2015 2:25:31 PM •
Oreck Air...
Answered
on Nov 06, 2015
Red light stays on after cleaning
which model, do you hear arcing or snapping sounds when it's running? Check wires that run along the inside front of the cell, loose, sagging or broken wires will cause this.
11/6/2015 2:16:28 PM •
Oreck Air...
Answered
on Nov 06, 2015
Can you add a prefilter to an oreck truman cell to grab the larger dust particles and decrease the zapping?a humidifier in the room helps but when the furnace is going it can still be often.
it should have a prefilter already on it. they have a screen looking filter that goes on the front of the cell. If you don't have one you need to get one. You should also have a charcoal filter on the back side of the cell, if not then you'll need to get one of those also, the charcoal is for odors and not for filtering dust. Putting any other type of filter in front of the cell will just be turning this into a filter type cleaner and will be defeating the purpose of the reusable Trueman cell. You may as well just buy a different cleaner if you don't mind buying new filters instead of cleaning the cell. I would recommend cleaning the cell every 2 weeks to keep it working properly. This will also keep it from snapping, if yours is snapping it's already too dirty and needs to be cleaned, if it's snapping right after it's cleaned then you have a plate that is arcing in the Trueman Cell, I have posted a fix for the ProSheild Models to stop the cell plates from arcing.
11/6/2015 1:51:49 PM •
Oreck Air...
Answered
on Nov 06, 2015
How to get the collected cell light to go out on 2 day old oreck pro shell air cleaner
I had one of these with the same exact problem, does your cell require some extra effort to push it into position? If it does it has the same problem as mine, after much examination I found the cell was getting squeezed on the sides near the back of the cell holding area. when the cell is in place it was getting compressed slight and the back edge of the plates were buckling just slightly enough to move the plates closer together, maybe 1/32" is all it takes to get them close enough to create an arc or short. I jammed something in the area where the switch is and left the front cover off and also removed the front screen, then I turned off the lights and started the unit and saw that there were sparks along the back edge of the plates. I removed the cell and saw no reason for the arcing but once I put the cell back in place I looked with a light shining inside the cell and noticed that there was a slight buckling of the plates and I filed off the plastic cell plate holder assembly on both sides of the the trueman cell. I eventually used a grinder to remove the extra material, I took off quite a bit of material before it fit without binding. It was working without any problems once I did this fix. I would bet everything that you have the same exact problem, I think they made the mold incorrectly for these units and won't acknowledge the problems. Should have been a complete recall. It's an easy fix once you know what the problem is.
11/6/2015 1:30:43 PM •
Oreck Air...
Answered
on Nov 06, 2015
