20 Most Recent Acer Aspire 5349-2592 Intel Celeron B800 1.5GHz 2Gb 250Gb DVDR/Rw 15.6 Questions & Answers
Hello there
Hints:
1) defective hard disk, you may need to RMS these drive.
2) BAD SECTOR on disk drive
3) sometimes using a testing tool may help, like the seagate tool for hard disk or western digital.
Acer Aspire... | Answered on Feb 02, 2017
Hey
Take Support from the expert on 1-877-778-89-69.
WELCOME TO RESOLIT
Acer Aspire... | Answered on Sep 26, 2016
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
http://www.nextag.com/dvd-lens-cleaner/shop-html
http://www.infopackets.com/news/hardware/2005/20050315_clean_cd_or_dvd_rom_lens_with_a_brush_part_2.htm
Acer Aspire... | Answered on Sep 28, 2013
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Acer Aspire... | Answered on Dec 04, 2012
Here's how to use Windows Password Recovery Standard to reset Windows without a password.
Step1: Get Windows Password Recovery Standard from: http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD to burn Windows XP password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD.
Step5: Start to perform Acer password reset with the burned disk.
Step6: Reboot computer and login to the machine without password.
(Note: Before starting password reset on Windows process with Windows Password Recovery Standard, you need to find another accessible computer and an empty CD/DVD.)
Acer Aspire... | Answered on Jun 19, 2012
http://download.cnet.com/intel-chipset-driver-7/3000-2122_4-162211.html
http://download.cnet.com/chipset-driver-intel-ver/3000-2122_4-162229.html
http://download.cnet.com/802-11g-wireless-lan/3000-2112_4-162293.html
if these driver packages are not right http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
hope this helps
Acer Aspire... | Answered on May 01, 2012
Statement or question, if the latter, what is it.
Acer Computers &... | Answered 3 days ago
You can use a DVD copy program like Nero if there is one on your computer.
Nero checks to make sure that you DVD isn't copy protected before it copies it. If it is you won't be able to copy it.
Windows XP or Vista does't provide DVD copy software built into Windows.
Acer Computers &... | Answered on Jun 30, 2020
*try it in other system
* change the cable of dvd
series is 9300
9300-3375
Driver Category Vendor Description Version Size Date Audio Realtek Audio Driver 6.0.1.5322 33.0 MB 2008/12/02 Download Bluetooth Broadcom Bluetooth Driver 6.0.1.3500 44.1 MB 2008/12/02 Download Camera Acer Camera Driver 6.96.0.15 12.6 MB 2008/12/02 Download Camera Bison Camera Driver 6.32.700.01 8.9 MB 2008/12/02 Download Camera Suyin Camera Driver 5.7.19.0 16.5 MB 2008/12/02 Download CardReader TI Card Reader Driver 2.0.0.6 4.9 MB 2008/12/02 Download Chipset NVIDIA Chipset Driver 1 48.2 MB 2008/12/02 Download Modem Foxconn Modem Driver 7.60.0.0 2.1 MB 2008/12/02 Download SATA NVIDIA SATA Driver 5.10.2600.0930 444.9 KB 2008/12/02 Download TouchPad Synaptics Touchpad Driver 9.0.3.0 4.9 MB 2008/12/02 Download VGA NVIDIA VGA Driver 97.55 34.2 MB 2008/12/02 Download Wireless LAN Atheros Wireless LAN Driver 7.2.0.152 2.8 MB 2008/12/02 Download Wireless LAN Broadcom Wireless LAN Driver 4.102.15.53 2.9 MB 2008/12/02 Download
  • Documents
  • BIOS/Firmware
  • Patch
  • Application
  • O.S.
  • Category Vendor Description Version Size Date Audio Realtek Audio Driver 6.0.1.5322 33.0 MB 2008/12/02 Download Bluetooth Broadcom Bluetooth Driver 6.0.1.3500 44.1 MB 2008/12/02 Download Camera Acer Camera Driver 6.96.0.15 12.6 MB 2008/12/02 Download Camera Bison Camera Driver 6.32.700.01 8.9 MB 2008/12/02 Download Camera Suyin Camera Driver 5.7.19.0 16.5 MB 2008/12/02 Download CardReader TI Card Reader Driver 2.0.0.6 4.9 MB 2008/12/02 Download Chipset NVIDIA Chipset Driver 1 48.2 MB 2008/12/02 Download Modem Foxconn Modem Driver 7.60.0.0 2.1 MB 2008/12/02 Download SATA NVIDIA SATA Driver 5.10.2600.0930 444.9 KB 2008/12/02 Download TouchPad Synaptics Touchpad Driver 9.0.3.0 4.9 MB 2008/12/02 Download VGA NVIDIA VGA Driver 97.55 34.2 MB 2008/12/02 Download Wireless LAN Atheros Wireless LAN Driver 7.2.0.152 2.8 MB 2008/12/02 Download Wireless LAN Broadcom Wireless LAN Driver 4.102.15.53 2.9 MB 2008/12/02 Download
    Drivers and Manuals
    Acer Computers &... | Answered on May 26, 2020
    Go to videohelp.com and read up on region settings.Lots of info there.
    Acer Computers &... | Answered on May 19, 2020
    sure you have blue ray?
    Acer Computers &... | Answered on May 07, 2020
    no laptop stated at all, just ACER..
    Take out the big battery, first.
    leave it out
    now plug in AC pack. wall AC to PC.
    it the screen must show at least errors or text of some kind
    if not the PC is dead. (we test the pack with a voltmeter) ask
    or get the PC serviced in a shop.
    Acer Computers &... | Answered on Apr 23, 2020
    This is unlikely to help. Firstly a clarification. Blu-Ray discs and DVDs are two different types of discs. A standard DVD drive, found in more computers, cannot play Blu-Ray discs. Firstly, insure that your computer has a BR drive. In the case of a desktop PC, there should be a logo on the front of the drive that will indicate. In the case of laptops and netbooks, the logo should be on the bottom of the device. Otherwise you may check the device's properties in the Control Panel to be certain.
    Assuming your device does support Blu-Ray, you must have special software to play it. The most common and well supported is Cyberlink's PowerDVD application. Despite the name, it plays BR discs are well. You can buy it at the Cyberlink website here:
    http://www.cyberlink.com/products/powerdvd/overview_en_US.html
    However, if your device has a BR capable drive, it's likely that BR software was included with it. Check any installation discs that came with your computing device.
    Computers &... | Answered on Apr 20, 2020
    Acer Aspire 5349-2592 Intel Celeron B800 1.5GHz 2Gb 250Gb DVDR/Rw 15.6 Logo
    18 questions posted
    Ekse
    Lee Hodgson
    Lee Hodgson
    Gustavo Ortiz
    Gustavo Ortiz
    View Most Popular
    • Acer Computers & Internet
    Most Popular Question
    am getting harddisk security notice
    • Computers & Internet
