20 Most Recent Presto Scandinavian Design Coffee Maker Questions & Answers
COFFEE MAKER PRESTO SCANDINAVIAN DESIGN MODEL INOPERATIVE
Sorry to hear.  when mine did this you had to cycle the on button from off-auto-on wait 6 sec and do it again and again till brewed.  Took about 10 min to brew the pot.  seems there is something wrong with the brew heater or thermal switch.  my hotplate got hot but would not brew.
 Called Presto and they said its discontinued.  They also said they just put their name on the product and never carried or serviced this model.  If they had a return they would just give a new one but since it is discontinued they cant even do that.  If you have a costco near buy you can take it back as a gift and they sold it for 35.00.  If its under a year old Presto will give you 1/3 the price towards another Presto product.  yay.
10/22/2008 12:23:07 AM • Presto... • Answered on Oct 22, 2008
I have a WMF Presto coffee machine and when I switch it on it comes up with WMF-AG V-Bootmanager 9,0 USB 1.1 on the screen and cannot do anything at all with the machine
The message you are seeing on your WMF Presto coffee machine suggests that it is stuck in the boot process and is unable to start up properly. This could be caused by a software or hardware issue. Here are some steps you can try to troubleshoot the issue:
  1. Check the power supply: Make sure that the machine is properly plugged into an electrical outlet and that the outlet is functioning correctly. If the outlet is not working, try plugging the machine into a different outlet.
  2. Restart the machine: Try turning the machine off and on again to see if it resolves the issue. If this doesn't work, try unplugging the machine from the power source, wait for a few seconds, and then plug it back in.
  3. Check the USB port: The message you are seeing on the screen suggests that the machine is looking for a USB device. Check to make sure that there is no USB device plugged into the machine. If there is, remove it and try restarting the machine.
  4. Contact the manufacturer: If none of these steps work, it may be a hardware issue. Contact the manufacturer or a qualified technician to diagnose and fix the issue.
It's important to note that attempting to fix the machine yourself may void the warranty or cause further damage.
2/20/2023 7:31:07 AM • Presto Coffee... • Answered on Feb 20, 2023
How to replace control battery wmf presto coffee machine
https://www.manualslib.com/manual/879035/Wmf-Presto.html?page=21
5/8/2022 4:06:06 PM • Presto Coffee... • Answered on May 08, 2022
Electric perculator plug
The common peoblem with these types of heating devices (coffee makers etc) is that the female portion of the plug gets hot over time and becomes loose. As it gets looser in heats up because of the bad electrical connection. Your only option is to buy another plug and cord. Attempting to repair is not feasible, and can actually have negative effects, like causing a fire or a electrical spark. You can find a lot of replacement parts on line by goggling your model number. Good luck to you....
8/19/2014 6:17:34 PM • Presto Coffee... • Answered on Aug 19, 2014
Question about the De Longhi Magnifica coffee machine.
These machines need dealer servicing every 6 to 12 months. They don't tell you that when you buy them. There are some ideas here https://www.google.com/search?q=De+Longhi+Magnifica+warning+triangle ..
4/16/2024 2:41:15 AM • Coffee Makers &... • Answered 6 hours ago
SCHAERER VERISMO 701 AMBIANTE 15 ESPRESSO MACHINE. We have to reset the Verismo 701 continuously even when we have the beans container filled up to the top.
Question edited for clarity. These machine need dealer servicing every 6 to 9 months depending on usage. They don't tell you this when you buy them, but I have been fighting these types of machines for the 9 years before I retired. One place had 2 machines and another has 6. Once machine did 1,200 cups a days and was serviced every month. Airport Business Class Lounges. ..
4/12/2024 5:42:30 AM • Coffee Makers &... • Answered on Apr 12, 2024
2answers
Where can I find Cecilware 3K-GB-LD Cappuccino machine Error Codes, I'm getting ERR 1 on my machine
To find Cecilware 3K-GB-LD Cappuccino machine error codes like "ERR 1," refer to the machine's user manual or technical documentation. Alternatively, contact Cecilware customer support for assistance in diagnosing and resolving the specific error code on your machine.
4/6/2024 8:13:43 PM • Coffee Makers &... • Answered on Apr 06, 2024
Capresso "Perk" Percolator Coffee Maker, 12 Cup. I have 2 percolator model 405.05 and the cord burned out on both i would like to replace the cords
Question edited for a lot more clarity. This is a very standard appliance plug that you can get from Walmart, Home Depot any small appliance store or even Amazon https://ecscoffee.com/products/capresso-12-cup-perculator-405-05 They look to be here https://www.google.com/search?q=percolator+model+405.05+replacement+cord ..
4/3/2024 6:29:51 PM • Coffee Makers &... • Answered on Apr 03, 2024
Looking for instructions for sansui espresso maker. model EM 208. 850 W.
Sasui em 208 coffee machine manual
3/22/2024 3:57:55 PM • Coffee Makers &... • Answered on Mar 22, 2024
2answers
Russell Hobbs Kudos 11418 coffee machine. Does anyone have a manual for it please?
I would go on the Russel Hobbs web site and download one. https://en.russellhobbs.com/user-manuals
3/21/2024 8:56:43 PM • Coffee Makers &... • Answered on Mar 21, 2024
How to repair toggle switches on cuisinart dgb900 coffee maker
You can replace them but unlikely to repair them. The casing will come apart, with some difficulty. Remove the old switch, source an identical new switch and fit it.
3/12/2024 11:29:39 PM • Coffee Makers &... • Answered on Mar 12, 2024
Why Jura ENA 1 wont turn on?
You simply have power supply board problem(PSU)
2/29/2024 6:17:17 AM • Coffee Makers &... • Answered on Feb 29, 2024
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
2/16/2024 6:02:28 PM • Coffee Makers &... • Answered on Feb 16, 2024
What does a CIMBALI M34 CODES ERROR 053 mean?
That .depends on software and configuration. It is not a universal code You might find help in the manual. CIMBALI M34 SELECTRON USE AND INSTALLATION Pdf Download ' ManualsLib Inspect Electrical Supply: Ensure that the machine is receiving proper electrical power. Sometimes, an interruption in the power supply can trigger error codes. Clean Components: Check if any components related to coffee grounds or filters are dirty or clogged. Clean the underpan gasket, filter holes, and filter holder outlet hole. Coffee Ground Quality: Verify that the coffee grounds are of the correct consistency. If they are too coarse or too old, it can affect the machine's operation. Discharge System: Examine the discharge system for any blockages.
2/15/2024 9:55:06 PM • Coffee Makers &... • Answered on Feb 15, 2024
I'm helping a neighbour with their k111 coffee maker. The on/off light is red? Does it change to green when ready? The line with ** is green. No water is coming through the pod. It is also very noisy.
The K111 coffee maker's red light typically indicates it's in the heating process. When ready, the light may change to green. The green line with ** suggests that it's in the brewing stage. If there's no water flow through the pod and it's noisy, check if the water reservoir is properly filled and securely placed. If the issue persists, consider contacting the manufacturer's customer support for assistance.
2/5/2024 12:15:19 AM • Coffee Makers &... • Answered on Feb 05, 2024
Presto Scandinavian Design Coffee Maker Logo
3 questions posted
Top Presto Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Presto Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Presto Coffee Makers & Espresso...
  • Presto Coffee Makers & Espresso...
Most Popular Question
coffee maker presto scandinavian design
  • Coffee Makers & Espresso Machines
